I have a problem with the certificate chain. How can I combine “intermediate certificate”, “root ca” and certificate on Caddy server. The tls directive accepts only the keys certificate.pem and privatekey.pem: tls cert (https://caddyserver.com/docs/tls)
Test result SSL Check to make sure your certificate is installed properly “Not all intermediate certificates” Indirect certificates are not transferred. Some browsers report “unsafe ssl connection”. There is nothing in Caddy’s documentation.
Thank you for your help
Hi @bartosz,
Generally you can just concatenate the keys into a text file.
Here’s a good resource - ignore the parts where they say to log in and download the certs, and substitute in your own from your cert provider: https://www.digicert.com/ssl-support/pem-ssl-creation.htm
It’s works, thanks a lot
