Cert expired didn't auto renew
Today the cert of my domain https://cuantificalo.com/ expired and I don’t know why it didn’t the auto renew.
I tried with:
  • sudo letsencrypt renew
  • sudo certbot certonly --force-renew -d cuantificalo.com
    but doesn’t works
what can I check? or what can I try?
thank you!!!
Hi @irob, welcome to the Caddy community.
Both of those commands are separate programs to Caddy, which manages its own certificates automatically.
Can you tell us:
  • How do you run Caddy?
  • What’s in your Caddyfile?
  • Do you have process logs you can post?
ok, now its renewed, I rebooted the AWS instance, and run ‘caddy’ again, I think that solves the solved the problem.
