2.3.0
Docker-based, base OS is Debian.
build: .
- web_proxy
- 443:443
restart: always
- /etc/docker_services/caddy/conf:/etc/caddy
- /srv/caddy:/data
- /srv/web:/srv
- /etc/letsencrypt:/certs
web_proxy:
external: true
example.com {
root * /srv/example.com
example.org {
root * /srv/example.org
tls /certs/live/example.org/fullchain.pem /certs/live/example.org/privkey.pem
:443 {
redir https://example.org/owa
tls internal {
on_demand
My Caddy instance serves multiple domains, some with externally provided TLS certs and mounted into the container, others relying on ACME via Caddy. In case someone connects directly to the public IP address, I would like for Caddy to serve a default redirection to one of the other domains. However, with the configuration above the matcher :443
seems to overwrite the TLS config for example.com
, but not the one for example.org
. More specifically, with the config above (and real domain names),
example.org
serves the correct site and uses the external TLS certificate -
example.com
also serves the correct site, but doesn’t rely on ACME anymore and suddenly also uses a certificate generated fromtls internal
https://<IP>
redirects as expected and uses an internal cert, as intended.
As an alternative, I tried to specify just the external IP of the host:
1.2.3.4 {
tls internal
However, Caddy doesn’t like that:
{"level":"debug","ts":1616175933.7395344,"logger":"http.stdlib","msg":"http: TLS handshake error from 1.2.3.4:55544: no certificate available for '172.18.0.3'"}
172.18.0.3
being the internal docker IP and subject to change. It does work when adding that one as a second IP, though:
1.2.3.4, 172.18.0.3 {
tls internal
But since that internal IP is unpredictable, I don’t like to fix that in my config. Is there some sort of generic IP catch-all matcher?
Just for the sake of completion: Just using the internal IP as a matcher returns a HTTP 200 without any content when accessing the site via IP directly. The debug log is empty in that case. Why is that?
172.18.0.3 {
tls internal
$ curl -vk https://1.2.3.4
< HTTP/2 200
< server: Caddy
< content-length: 0
