Can't use copy_headers in clear-text forward_auth to pass to reverse_proxy upstream
I’m using Caddy as a top-level reverse proxy for several microservices, including one for auth via forward_auth, which returns a custom header called X-User-Facts. This is supposed to be passed to the appropriate other microservice via reverse_proxy and copied back to the final response. Copying to the response works reliably. Unfortunately, the upstream microservices only see the literal Caddy placeholder for the header name, not the value of it: log messages contain the literal string {http.reverse_proxy.header.X-User-Facts} rather than any actual header value.
This is all being run on a single dev machine, with /etc/hosts including some custom domains for TLS support, and Cloudflare DNS-01:
127.0.0.1	iops3-dev.farmersfriendllc.com
127.0.0.1	auth.iops3-dev.farmersfriendllc.com
Synthesizing fake auth and upstream microservices with Caddy listeners produces an interesting result: I get the correct behavior if the mock for forward_auth uses TLS in its HTTP transport, but not if it is in cleartext. (It doesn’t matter whether reverse_proxy is using TLS or not.)
Obvious workaround having gone through all this
Sticking another Caddy layer around the real auth microservice to enable forward_auth via TLS is effective, but it’s an annoying hack and I don’t understand why it’s necessary. (It’s also a trap for the unwary, since one must use header_up Host {upstream_hostport} or similar rewrite to avoid infinite loops. I suppose it’s also a bit of a performance drain, but a few ms latency and a small extra CPU usage are unlikely to be too big a deal in our case.)
After curl -L https://iops3-dev.farmersfriendllc.com:8585/inv/parts:
{"level":"debug","ts":"2024-08-21T15:33:27.644-0500","logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"localhost:9004","total_upstreams":1}
{"level":"debug","ts":"2024-08-21T15:33:27.645-0500","logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:9004","duration":0.000805378,"request":{"remote_ip":"127.0.0.1","remote_port":"63399","client_ip":"127.0.0.1","proto":"HTTP/2.0","method":"GET","host":"iops3-dev.farmersfriendllc.com:8585","uri":"/","headers":{"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["iops3-dev.farmersfriendllc.com:8585"],"X-Forwarded-Method":["GET"],"X-Forwarded-Uri":["/inv/parts"],"User-Agent":["curl/8.4.0"],"Accept":["*/*"],"X-Forwarded-For":["127.0.0.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"iops3-dev.farmersfriendllc.com"}},"headers":{"Server":["Caddy"],"Date":["Wed, 21 Aug 2024 20:33:27 GMT"],"Content-Length":["0"]},"status":200}
{"level":"debug","ts":"2024-08-21T15:33:27.645-0500","logger":"http.handlers.reverse_proxy","msg":"handling response","upstream":"localhost:9004","duration":0.000805378,"request":{"remote_ip":"127.0.0.1","remote_port":"63399","client_ip":"127.0.0.1","proto":"HTTP/2.0","method":"GET","host":"iops3-dev.farmersfriendllc.com:8585","uri":"/","headers":{"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["iops3-dev.farmersfriendllc.com:8585"],"X-Forwarded-Method":["GET"],"X-Forwarded-Uri":["/inv/parts"],"User-Agent":["curl/8.4.0"],"Accept":["*/*"],"X-Forwarded-For":["127.0.0.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"iops3-dev.farmersfriendllc.com"}},"handler":0}
{"level":"debug","ts":"2024-08-21T15:33:27.645-0500","logger":"http.handlers.rewrite","msg":"rewrote request","request":{"remote_ip":"127.0.0.1","remote_port":"63399","client_ip":"127.0.0.1","proto":"HTTP/2.0","method":"GET","host":"iops3-dev.farmersfriendllc.com:8585","uri":"/inv/parts","headers":{"User-Agent":["curl/8.4.0"],"Accept":["*/*"],"X-User-Facts":["{http.reverse_proxy.header.X-User-Facts}"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"iops3-dev.farmersfriendllc.com"}},"method":"GET","uri":"/parts"}
You can see the uninterpreted placeholder in the headers on the last line, and no sign of the X-User-Facts header otherwise.
xcaddy build --with github.com/caddy-dns/cloudflare and then copied the binary to an appropriate place.
macOS 12.7.5 (Intel).
caddy start --watch
(For most of these, I also had to add --adapter caddyfile --config <xyz>.Caddyfile.)
(None.)
Original, suitably trimmed to give minimal repro case:
	#email ... whatever...
	acme_dns cloudflare {env.CF_API_TOKEN}
	log default {
		output file caddy_log/json.log
		format json {
			time_format iso8601
iops3-dev.farmersfriendllc.com:8585 {
	# XXX: Non-functional, but https://iops3-dev.farmersfriendllc.com:9003 is fine
	forward_auth localhost:9004 {
		uri /
		copy_headers X-User-Facts
	handle_path /inv/* {
		reverse_proxy https://iops3-dev.farmersfriendllc.com:9001 {
	log
	encode zstd gzip
Fake upstream (also tried adding http://iops3-dev.farmersfriendllc.com:9000 block and adjusting others to reference it, but it made no difference):
	log default {
		output file caddy_log/test.log
		format json {
			time_format iso8601
	respond "X-User-Facts was: {header.X-User-Facts}"
	handle_errors {
		respond "{err.status_code} (pseudo-micro-service) {err.status_text}"
	log
Fake auth:
	log default {
		output file caddy_log/test-auth.log
		format json {
			time_format iso8601
iops3-dev.farmersfriendllc.com:9003 {
	header X-User-Facts "Testing value"
	respond 200 {
		body "OK"
	handle_errors {
		respond "{err.status_code} (pseudo-auth-service) {err.status_text}"
	log
http://localhost:9004 {
	respond 200 {
		body "OK"
	handle_errors {
	log
Your forward_auth backend doesn’t actually reply with X-User-Facts so there’s no header value, so the placeholder doesn’t get replaced.
The problem is that your upstream uses localhost as the Host matcher, but forward_auth (and reverse_proxy) preserve the original Host header, so your upstream server doesn’t match the site block your defined and instead simply responds with an empty response.
Either remove localhost from your site address (i.e. just use :9004 as the site address) or override the Host header with header_up Host localhost in your forward_auth.
