Can't mount Caddyfile when using docker context (remote machine)
Can’t mount Caddyfile when using docker context. However, once I move the compose file over to the remote machine (along with the relevant files) it works fine.
steps to reproduce
docker context create <NAME> --docker "host=ssh://<HOST>"
docker context use <NAME>
docker compose up -d
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during con
tainer init: error mounting "/home/user/Code/homelab-setup/caddy/config/Caddyfile" to rootfs at "/etc/caddy/Caddyfile": create mountpoint for /etc/caddy/Caddyfile mount: cannot create subdi
rectories in "/var/lib/docker/overlay2/bb5c9bfc60c81ef1606663b988c2901c3b3f25ce7e62366dafd8451646aa9631/merged/etc/caddy/Caddyfile": not a directory: Are you trying to mount a directory onto
a file (or vice-versa)? Check if the specified host path exists and is the expected type
command output
docker image ls
caddy                                            latest      14300de7e087   3 weeks ago     50.5MB
docker compose exec -it caddy caddy version
docker compose
Docker with compose
    image: caddy:latest
      - "443:443/udp"
      - ./caddy/config/Caddyfile:/etc/caddy/Caddyfile
      # - ./caddy/config/http.Caddyfile:/config/http.Caddyfile
      # - ./.Caddyfile.txt:/opt/caddy/Caddyfile:ro
      # - ./caddy/config:/etc/caddy
      # - ./caddy/config/Caddyfile:/etc/caddy/Caddyfile:ro
      - ./caddy/certs:/certs:ro
      - caddy_data:/data
    # command: /usr/bin/caddy run --config /config/http.Caddyfile
This is just temporary for testing purposes
    respond "Hello World!"
Edit 1: adding steps to reproduce
This is a Docker question, so we can’t guarantee Docker experts are around to answer. My Docker knowledge isn’t advanced enough to answer that question, but I hope other users are able to answer.
