1. Output of caddy version
I run caddy via docker-compose using caddy:2.6.2-alpine image
DietPi v8.9.2, running caddy via docker
docker-compose up caddy
version: '3.7'
vaultwarden:
image: vaultwarden/server:1.26.0-arm32v6
container_name: vaultwarden
restart: always
- WEBSOCKET_ENABLED=true
- ./vw-data:/data
image: caddy:2.6.2-alpine
restart: always
- 443:443
- ./caddy-config:/config
- ./caddy-data:/data
- ./caddy-certs:/certs
- ./caddy-download:/downloadables
- "DOMAIN_LIST=https://vaultwarden.home.lan:443, https://vaultwarden:443"
- LOG_FILE=/data/access.log
- CA_CERT=/certs/root.crt
- CA_KEY=/certs/root.key
pki {
ca vw-ca {
root {
cert {$CA_CERT}
key {$CA_KEY}
{$DOMAIN_LIST} {
level INFO
output file {$LOG_FILE} {
roll_size 10MB
roll_keep 10
# Enable TLS
issuer internal {
ca vw-ca
sign_with_root
# Enable compression
# Downloadables folder (CA cert)
handle /downloadables/* {
root * /downloadables
# Notifications redirected to the WebSocket server
handle /notifications/hub {
reverse_proxy vaultwarden:3012
# Proxy everything else to Rocket
reverse_proxy vaultwarden:80 {
I’m trying to use self-signed trusted root certificate to make Caddy automatically issue certificates for my vaultwarden.home.lan
and vaultwarden
domains. For some reason, Caddy gives me this weird error that I couldn’t find any valuable info about: x509: requested SignatureAlgorithm does not match private key type
. My private key type is 4096-bit RSA.
Currently using those two commands to generate my private key/certificate files:
$ openssl genrsa -out root.key 4096
$ openssl req -x509 -sha256 -new -nodes -key root.key -days 7300 -out root.crt
The problem is that SignatureAlgorithm does not match private key type
message doesn’t leave me any clues… What type does my private key needs to be? Interesting thing is, it worked flawlessly for almost a year before I decided to make a clean install of DietPi, copying all of my previous Caddy/Vaultwarden/Docker data to it, not making any changes to the config files.
{"level":"info","ts":1666137956.5622864,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1666137956.6879723,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1666137956.735624,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1666137956.8141751,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x38f5270"}
{"level":"info","ts":1666137956.9496994,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1666137956.9571142,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1666137956.9801853,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1666137956.9876792,"msg":"failed to sufficiently increase receive buffer size (was: 176 kiB, wanted: 2048 kiB, got: 352 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
{"level":"debug","ts":1666137956.9999893,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
{"level":"info","ts":1666137957.0074394,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"debug","ts":1666137957.0196562,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
{"level":"info","ts":1666137957.0279973,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1666137957.0363963,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["vaultwarden","vaultwarden.home.lan"]}
{"level":"info","ts":1666137957.0647142,"logger":"tls.obtain","msg":"acquiring lock","identifier":"vaultwarden.home.lan"}
{"level":"info","ts":1666137957.0792642,"logger":"tls.obtain","msg":"acquiring lock","identifier":"vaultwarden"}
{"level":"info","ts":1666137957.1380982,"logger":"tls.obtain","msg":"lock acquired","identifier":"vaultwarden.home.lan"}
{"level":"info","ts":1666137957.1482213,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"vaultwarden.home.lan"}
{"level":"debug","ts":1666137957.1558852,"logger":"events","msg":"event","name":"cert_obtaining","id":"e8b7588e-08ec-4a56-9813-ca4f0470169d","origin":"tls","data":{"identifier":"vaultwarden.home.lan"}}
{"level":"info","ts":1666137957.1646152,"logger":"tls.obtain","msg":"lock acquired","identifier":"vaultwarden"}
{"level":"info","ts":1666137957.20883,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"vaultwarden"}
{"level":"debug","ts":1666137957.2344093,"logger":"events","msg":"event","name":"cert_obtaining","id":"6a8e512d-0f2c-4785-b73a-fa6dd6becda7","origin":"tls","data":{"identifier":"vaultwarden"}}
{"level":"debug","ts":1666137957.233992,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"vw-ca"}
{"level":"debug","ts":1666137957.3109512,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"vw-ca"}
{"level":"error","ts":1666137957.63976,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"vaultwarden.home.lan","issuer":"vw-ca","error":"authority.Sign; error creating certificate: error creating certificate: x509: requested SignatureAlgorithm does not match private key type","errorVerbose":"x509: requested SignatureAlgorithm does not match private key type\nerror creating certificate\ngo.step.sm/crypto/x509util.CreateCertificate\n\tgo.step.sm/crypto@v0.18.0/x509util/certificate.go:184\ngithub.com/smallstep/certificates/cas/softcas.createCertificate\n\tgithub.com/smallstep/certificates@v0.22.1/cas/softcas/softcas.go:258\ngithub.com/smallstep/certificates/cas/softcas.(*SoftCAS).CreateCertificate\n\tgithub.com/smallstep/certificates@v0.22.1/cas/softcas/softcas.go:80\ngithub.com/smallstep/certificates/authority.(*Authority).Sign\n\tgithub.com/smallstep/certificates@v0.22.1/authority/tls.go:228\ngithub.com/caddyserver/caddy/v2/modules/caddytls.InternalIssuer.Issue\n\tgithub.com/caddyserver/caddy/v2@v2.6.2/modules/caddytls/internalissuer.go:131\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:554\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:611\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:462\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:359\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:73\nruntime.goexit\n\truntime/asm_arm.s:831\nauthority.Sign; error creating certificate\ngithub.com/smallstep/certificates/errs.Wrap\n\tgithub.com/smallstep/certificates@v0.22.1/errs/error.go:99\ngithub.com/smallstep/certificates/authority.(*Authority).Sign\n\tgithub.com/smallstep/certificates@v0.22.1/authority/tls.go:236\ngithub.com/caddyserver/caddy/v2/modules/caddytls.InternalIssuer.Issue\n\tgithub.com/caddyserver/caddy/v2@v2.6.2/modules/caddytls/internalissuer.go:131\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:554\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:611\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:462\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:359\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:73\nruntime.goexit\n\truntime/asm_arm.s:831"}
{"level":"debug","ts":1666137957.7061722,"logger":"events","msg":"event","name":"cert_failed","id":"e52e06d3-f34d-435c-bab6-0d2a0baf3829","origin":"tls","data":{"error":{"status":500,"message":"The certificate authority encountered an Internal Server Error. Please see the certificate authority logs for more info."},"identifier":"vaultwarden.home.lan","issuers":["vw-ca"],"renewal":false}}
{"level":"error","ts":1666137957.7141402,"logger":"tls.obtain","msg":"will retry","error":"[vaultwarden.home.lan] Obtain: authority.Sign; error creating certificate: error creating certificate: x509: requested SignatureAlgorithm does not match private key type","attempt":1,"retrying_in":60,"elapsed":0.567696,"max_duration":2592000}
{"level":"error","ts":1666137957.7444441,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"vaultwarden","issuer":"vw-ca","error":"authority.Sign; error creating certificate: error creating certificate: x509: requested SignatureAlgorithm does not match private key type","errorVerbose":"x509: requested SignatureAlgorithm does not match private key type\nerror creating certificate\ngo.step.sm/crypto/x509util.CreateCertificate\n\tgo.step.sm/crypto@v0.18.0/x509util/certificate.go:184\ngithub.com/smallstep/certificates/cas/softcas.createCertificate\n\tgithub.com/smallstep/certificates@v0.22.1/cas/softcas/softcas.go:258\ngithub.com/smallstep/certificates/cas/softcas.(*SoftCAS).CreateCertificate\n\tgithub.com/smallstep/certificates@v0.22.1/cas/softcas/softcas.go:80\ngithub.com/smallstep/certificates/authority.(*Authority).Sign\n\tgithub.com/smallstep/certificates@v0.22.1/authority/tls.go:228\ngithub.com/caddyserver/caddy/v2/modules/caddytls.InternalIssuer.Issue\n\tgithub.com/caddyserver/caddy/v2@v2.6.2/modules/caddytls/internalissuer.go:131\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:554\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:611\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:462\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:359\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:73\nruntime.goexit\n\truntime/asm_arm.s:831\nauthority.Sign; error creating certificate\ngithub.com/smallstep/certificates/errs.Wrap\n\tgithub.com/smallstep/certificates@v0.22.1/errs/error.go:99\ngithub.com/smallstep/certificates/authority.(*Authority).Sign\n\tgithub.com/smallstep/certificates@v0.22.1/authority/tls.go:236\ngithub.com/caddyserver/caddy/v2/modules/caddytls.InternalIssuer.Issue\n\tgithub.com/caddyserver/caddy/v2@v2.6.2/modules/caddytls/internalissuer.go:131\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:554\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:611\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:462\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.17.2/config.go:359\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.17.2/async.go:73\nruntime.goexit\n\truntime/asm_arm.s:831"}
{"level":"debug","ts":1666137957.7551541,"logger":"events","msg":"event","name":"cert_failed","id":"df7173e8-74a0-4fd7-9408-39160d6cace3","origin":"tls","data":{"error":{"status":500,"message":"The certificate authority encountered an Internal Server Error. Please see the certificate authority logs for more info."},"identifier":"vaultwarden","issuers":["vw-ca"],"renewal":false}}
{"level":"error","ts":1666137957.7610912,"logger":"tls.obtain","msg":"will retry","error":"[vaultwarden] Obtain: authority.Sign; error creating certificate: error creating certificate: x509: requested SignatureAlgorithm does not match private key type","attempt":1,"retrying_in":60,"elapsed":0.554023,"max_duration":2592000}
{"level":"info","ts":1666137958.8766544,"logger":"pki.ca.vw-ca","msg":"root certificate is already trusted by system","path":"/certs/root.crt"}
{"level":"info","ts":1666137958.9081242,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1666137958.9159842,"msg":"serving initial configuration"}
{"level":"info","ts":1666137958.9231052,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1666137958.925789,"logger":"tls","msg":"finished cleaning storage units"}
I tried to re-generate private key/certificate with RSA-4096 and ECDSA as my private key types, that’s the only thing I could think of given this strange error message…
