### 1. Caddy version (`caddy version`):
v2.3.0
### 2. How I run Caddy:
As a service on a raspberry pi4
#### a. System environment:
Pi-OS
#### b. Command:
#### c. Service/unit/compose file:
none
#### d. My complete Caddyfile or JSON config:
www.domain_1.nl {
reverse_proxy * 192.168.3.201:5000
www.domain_2.nl {
reverse_proxy * 192.168.3.200:31417
ha.domain_3.nl {
reverse_proxy * 192.168.3.175:8123
site.domain_2.nl {
root * 192.168.3.200/volume1/web/wordpress
php_fastcgi 192.168.3.200/run/php-fpm/php56-fpm.sock
### 3. The problem I'm having:
<!-- What are you trying to do, and what isn't working? Please describe the issue thoroughly enough so that anyone can reproduce the exact behavior you're seeing. Be as specific as possible. -->
I use caddy as a reverse proxy for two synology nas’s and for homeassistant. These three just work. I also want to host a website from one of the synologies. I installed it correctly, I think. I tried to use the same reverse proxy command as with the other ones. That worked locally. in the browser, but returned the local URL 192.168.3.200/wordpress. From the outside world that doesn’t work. I then read one of Matt’s tutorials on this topic and changed the caddyfile to what you see above. It still returns the local URL.
I’ve been going through this forum, but can’t find the solution. I just am too much of a rookie to really understand the issue.
### 4. Error messages and/or full log output:
No errors in caddy. The browser quiery just times out.
### 5. What I already tried:
As I explained above. I’ve read through the forum and some tutorials to no avail.
### 6. Links to relevant resources:
