v2.2.1
Ubuntu 20.04
I first installed Caddy using
$ echo "deb [trusted=yes] https://apt.fury.io/caddy/ /" \
| sudo tee -a /etc/apt/sources.list.d/caddy-fury.list
$ sudo apt update
$ sudo apt install caddy
Then I use the following code to start Caddy as a service.
# systemctl start caddy
# systemctl enable caddy
# systemctl status caddy
systemd file
# caddy.service
# for your installation.
Caddyfile
ryanyao.xyz{
root * /var/www/
The service is running, but I can’t access my domain.
caddy.HomeDir=/var/lib/caddy
Nov 27 22:53:21 server caddy[36067]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Nov 27 22:53:21 server caddy[36067]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Nov 27 22:53:21 server caddy[36067]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Nov 27 22:53:21 server caddy[36067]: caddy.Version=v2.2.1
Nov 27 22:53:21 server caddy[36067]: runtime.GOOS=linux
Nov 27 22:53:21 server caddy[36067]: runtime.GOARCH=amd64
Nov 27 22:53:21 server caddy[36067]: runtime.Compiler=gc
Nov 27 22:53:21 server caddy[36067]: runtime.NumCPU=3
Nov 27 22:53:21 server caddy[36067]: runtime.GOMAXPROCS=3
Nov 27 22:53:21 server caddy[36067]: runtime.Version=go1.15.2
Nov 27 22:53:21 server caddy[36067]: os.Getwd=/
Nov 27 22:53:21 server caddy[36067]: LANG=en_US.UTF-8
Nov 27 22:53:21 server caddy[36067]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Nov 27 22:53:21 server caddy[36067]: HOME=/var/lib/caddy
Nov 27 22:53:21 server caddy[36067]: LOGNAME=caddy
Nov 27 22:53:21 server caddy[36067]: USER=caddy
Nov 27 22:53:21 server caddy[36067]: INVOCATION_ID=ff988eb69d09442a9d52daa2e5097070
Nov 27 22:53:21 server caddy[36067]: JOURNAL_STREAM=9:178256
Nov 27 22:53:21 server caddy[36067]: {"level":"info","ts":1606517601.846735,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Nov 27 22:53:21 server caddy[36067]: {"level":"info","ts":1606517601.849302,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["127.0.0.1:2019","localhost:2019","[::1]:2019"]}
Nov 27 22:53:21 server caddy[36067]: {"level":"info","ts":1606517601.8495014,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Nov 27 22:53:21 server caddy[36067]: {"level":"info","ts":1606517601.8495169,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Nov 27 22:53:21 server caddy[36067]: {"level":"info","ts":1606517601.8523042,"msg":"autosaved config","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Nov 27 22:53:21 server caddy[36067]: {"level":"info","ts":1606517601.8523262,"msg":"serving initial configuration"}
I haven’t tried much, I don’t know why it won’t work. Looks like the server needs a TLS connection policy, but I don’t know what’s that means. I can’t find anything on the documentation as well.
