2.4.6
OSX 12.21 (tested with caddy on its own and the caddy docker image)
auto_https off
output stdout
route /api/* {
uri strip_prefix /api
reverse_proxy localhost:8000
handle /socket.io/* {
reverse_proxy localhost:3000
I am trying to run a create-react-app dev server and a nodejs-koa server behind the reverse proxy.
The nodejs server serves a regular REST-Api as well as a web socket.
The REST-API works fine, however I can’t get the socket to work correctly.
The server logic is mainly handled by the boardgame.io framework (I haven’t worked with sockets before).
The client dispatches multiple socket requests and then immediately closes the connection.
One of the requests gets an invalid message response.
The request after which the connection is being closed, gets three responses: a 2Probe, a 3Probe and then a 5 (without probe).
So as far as I understand this, the socket handshake works fine, but the upgrade from polling to websocket seems to fail somehow.
2022/02/23 20:21:49.753 DEBUG http.handlers.reverse_proxy upgrading connection {"upstream": "localhost:8000", "duration": 0.00099606, "r
equest": {"remote_addr": "127.0.0.1:65374", "proto": "HTTP/1.1", "method": "GET", "host": "localhost", "uri": "/socket.io/?EIO=4&transport=websock
et&sid=uT52lBfdW-BzGTu_AAAH", "headers": {"Accept": ["*/*"], "Sec-Websocket-Key": ["KLVFNjK1q2E8AqWXdPPw+w=="], "Dnt": ["1"], "Sec-Fetch-Dest": ["
websocket"], "Sec-Fetch-Mode": ["websocket"], "Accept-Language": ["en-US,de;q=0.7,en;q=0.3"], "Origin": ["http://localhost"], "Connection": ["Upgr
ade"], "Pragma": ["no-cache"], "Upgrade": ["websocket"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:98.0) Gecko/20100101 Fir
efox/98.0"], "Sec-Websocket-Version": ["13"], "Sec-Websocket-Extensions": ["permessage-deflate"], "Sec-Fetch-Site": ["same-origin"], "Cache-Contro
l": ["no-cache"], "X-Forwarded-For": ["127.0.0.1"], "X-Forwarded-Proto": ["http"], "Accept-Encoding": ["gzip, deflate"]}}}
2022/02/23 20:21:49.707 INFO http.log.access.log0 handled request {"request": {"remote_addr": "127.0.0.1:65372", "proto": "HTTP/1.1", "metho
d": "GET", "host": "localhost", "uri": "/socket.io/?EIO=4&transport=polling&t=NyeFqLg&sid=uT52lBfdW-BzGTu_AAAH", "headers": {"Referer": ["http://l
ocalhost/match/EMQ4lSS9ugp"], "Sec-Fetch-Site": ["same-origin"], "Cache-Control": ["no-cache"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac
OS X 10.15; rv:98.0) Gecko/20100101 Firefox/98.0"], "Accept": ["*/*"], "Accept-Encoding": ["gzip, deflate"], "Dnt": ["1"], "Connection": ["keep-al
ive"], "Sec-Fetch-Dest": ["empty"], "Sec-Fetch-Mode": ["cors"], "Pragma": ["no-cache"], "Accept-Language": ["en-US,de;q=0.7,en;q=0.3"]}}, "common_
log": "127.0.0.1 - - [23/Feb/2022:21:21:49 +0100] \"GET /socket.io/?EIO=4&transport=polling&t=NyeFqLg&sid=uT52lBfdW-BzGTu_AAAH HTTP/1.1\" 200 47",
"user_id": "", "duration": 0.114414626, "size": 47, "status": 200, "resp_headers": {"Date": ["Wed, 23 Feb 2022 20:21:49 GMT"], "Server": ["Caddy"
], "Access-Control-Allow-Origin": ["*"], "Content-Type": ["text/plain; charset=UTF-8"], "Content-Length": ["47"]}}
2022/02/23 20:21:49.858 DEBUG http.handlers.reverse_proxy connection closed {"upstream": "localhost:8000", "duration": 0.00099606, "r
l": ["no-cache"], "X-Forwarded-For": ["127.0.0.1"], "X-Forwarded-Proto": ["http"], "Accept-Encoding": ["gzip, deflate"]}}, "duration": 0.021453445
2022/02/23 20:21:49.874 INFO http.log.access.log0 handled request {"request": {"remote_addr": "127.0.0.1:65374", "proto": "HTTP/1.1", "method": "GET", "host": "localhost", "uri": "/socket.io/?EIO=4&transport=websocket&sid=uT52lBfdW-BzGTu_AAAH", "headers": {"Accept": ["*/*"], "Sec-Websocket-Key": ["KLVFNjK1q2E8AqWXdPPw+w=="], "Dnt": ["1"], "Sec-Fetch-Dest": ["websocket"], "Sec-Fetch-Mode": ["websocket"], "Accept-Language": ["en-US,de;q=0.7,en;q=0.3"], "Origin": ["http://localhost"], "Connection": ["keep-alive, Upgrade"], "Pragma": ["no-cache"], "Upgrade": ["websocket"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:98.0) Gecko/20100101 Firefox/98.0"], "Sec-Websocket-Version": ["13"], "Sec-Websocket-Extensions": ["permessage-deflate"], "Sec-Fetch-Site": ["same-origin"], "Cache-Control": ["no-cache"], "Accept-Encoding": ["gzip, deflate"]}}, "common_log": "127.0.0.1 - - [23/Feb/2022:21:21:49 +0100] \"GET /socket.io/?EIO=4&transport=websocket&sid=uT52lBfdW-BzGTu_AAAH HTTP/1.1\" 0 0", "user_id": "", "duration": 0.277013447, "size": 0, "status": 0, "resp_headers": {"Server": ["Caddy"], "Upgrade": ["websocket"], "Connection": ["Upgrade"], "Sec-Websocket-Accept": ["DvITbtqy+TWQKP8torDITZ+54lM="]}}
2022/02/23 20:21:49.874 INFO http.log.access.log0 handled request {"request": {"remote_addr": "127.0.0.1:65374", "proto": "HTTP/1.1", "method": "GET", "host": "localhost", "uri": "/socket.io/?EIO=4&transport=websocket&sid=uT52lBfdW-BzGTu_AAAH", "headers": {"Sec-Websocket-Extensions": ["permessage-deflate"], "Sec-Fetch-Site": ["same-origin"], "Cache-Control": ["no-cache"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:98.0) Gecko/20100101 Firefox/98.0"], "Sec-Websocket-Version": ["13"], "Accept-Encoding": ["gzip, deflate"], "Dnt": ["1"], "Sec-Fetch-Dest": ["websocket"], "Sec-Fetch-Mode": ["websocket"], "Accept": ["*/*"], "Sec-Websocket-Key": ["KLVFNjK1q2E8AqWXdPPw+w=="], "Connection": ["keep-alive, Upgrade"], "Pragma": ["no-cache"], "Upgrade": ["websocket"], "Accept-Language": ["en-US,de;q=0.7,en;q=0.3"], "Origin": ["http://localhost"]}}, "common_log": "127.0.0.1 - - [23/Feb/2022:21:21:49 +0100] \"GET /socket.io/?EIO=4&transport=websocket&sid=uT52lBfdW-BzGTu_AAAH HTTP/1.1\" 0 0", "user_id": "", "duration": 0.277013447, "size": 0, "status": 0, "resp_headers": {"Sec-Websocket-Accept": ["DvITbtqy+TWQKP8torDITZ+54lM="], "Server": ["Caddy"], "Upgrade": ["websocket"], "Connection": ["Upgrade"]}}
I tried to figure out a solution by reading this post: I can't get socket.io proxy to work on v2 - #2 by francislavoie
But I was not sure what /path would be in my case (and if I event need this, because the path seems to be fine).
The additional headers also didn’t seem to change anything.
Boardgame.io: GitHub - boardgameio/boardgame.io: State Management and Multiplayer Networking for Turn-Based Games · GitHub (this is the framework I am using)
