v2.4.5 - package from regular Manjaro Repositories
OS: “Manjaro Linux; Build ID: rolling”
- Use Caddy as systemd service
ISP: Google Fiber
- Use provided “Multi-Gig Router” required for 2 Gig service
- Used online cloud config to port forward 80 and 443 with “TCP & UDP”
- Firewall: Disabled, but also tried enabling and with incoming and outgoing set to “Allow”
DNS/Domain provider: Google Domains
- Using ddclient to auto-update my dynamic IP to Google Domains
To start caddy:
sudo systemctl start caddy
After adjusting Caddyfile
sudo systemctl reload caddy
or if needed:
sudo systemctl stop caddy
# caddy.service
# for your installation.
Description=Caddy web server
After=network-online.target
StartLimitIntervalSec=14400
StartLimitBurst=10
Environment=XDG_DATA_HOME=/var/lib
Environment=XDG_CONFIG_HOME=/etc
ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile
ExecStopPost=/usr/bin/rm -f /run/caddy/admin.socket
# Do not allow the process to be restarted in a tight loop. If the
# process fails to start, something critical needs to be fixed.
Restart=on-abnormal
# Use graceful shutdown with a reasonable timeout
# Hardening options
DevicePolicy=closed
LockPersonality=true
MemoryAccounting=true
MemoryDenyWriteExecute=true
NoNewPrivileges=true
PrivateDevices=true
ProcSubset=pid
ProtectClock=true
ProtectControlGroups=true
ProtectHome=true
ProtectHostname=true
ProtectKernelLogs=true
ProtectKernelModules=true
ProtectKernelTunables=true
ProtectProc=invisible
ProtectSystem=strict
RemoveIPC=true
ReadWritePaths=/var/lib/caddy /var/log/caddy /run/caddy
RestrictNamespaces=true
RestrictRealtime=true
RestrictSUIDSGID=true
Note: the domain is a joke so I can make my mother have to type it in to see my media which is mostly my professional photography & videography, there’s not really filthy pictures lol
https://filthy.pictures {
reverse_proxy localhost:8096
I’m attempting my first caddy deployment to allow my Jellyfin media server to be accessible remotely. I am unable to get https:// to work. I’m not sure really what to do. The browser says it refuses to connect. Seems like there’s issue with access to port 443 possibly. Any help would be really appreciated, and apologies if I’m just being stupid and missing something obvious.
~ >>> curl -v filthy.pictures:443
* Trying 136.35.97.6:443...
* connect to 136.35.97.6 port 443 failed: Connection refused
* Failed to connect to filthy.pictures port 443 after 3 ms: Connection refused
* Closing connection 0
curl: (7) Failed to connect to filthy.pictures port 443 after 3 ms: Connection refused
~ >>> curl -v filthy.pictures:80 [7]
* Trying 136.35.97.6:80...
* Connected to filthy.pictures (136.35.97.6) port 80 (#0)
> GET / HTTP/1.1
> Host: filthy.pictures
> User-Agent: curl/7.79.1
< Connection: close
< Location: https://filthy.pictures/
< Server: Caddy
< Date: Mon, 25 Oct 2021 04:13:59 GMT
< Content-Length: 0
Oct 24 12:12:09 TwinCity systemd[1]: Starting Caddy web server...
Oct 24 12:12:09 TwinCity caddy[53866]: {"level":"info","ts":1635095529.752518,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 24 12:12:09 TwinCity caddy[53866]: {"level":"warn","ts":1635095529.7530625,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Oct 24 12:12:09 TwinCity caddy[53866]: {"level":"info","ts":1635095529.753181,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Oct 24 12:12:09 TwinCity caddy[53866]: {"level":"info","ts":1635095529.7531905,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Oct 24 12:12:09 TwinCity caddy[53866]: {"level":"info","ts":1635095529.7534306,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002c7810"}
Oct 24 12:12:09 TwinCity caddy[53866]: {"level":"info","ts":1635095529.7536497,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0002c7810"}
Oct 24 12:12:09 TwinCity caddy[53866]: Valid configuration
Oct 24 12:12:09 TwinCity systemd[1]: Started Caddy web server.
Oct 24 12:12:09 TwinCity caddy[53878]: caddy.HomeDir=/var/lib/caddy
Oct 24 12:12:09 TwinCity caddy[53878]: caddy.AppDataDir=/var/lib/caddy
Oct 24 12:12:09 TwinCity caddy[53878]: caddy.AppConfigDir=/etc/caddy
Oct 24 12:12:09 TwinCity caddy[53878]: caddy.ConfigAutosavePath=/var/lib/caddy/autosave.json
Oct 24 12:12:09 TwinCity caddy[53878]: caddy.Version=v2.4.5
Oct 24 12:12:09 TwinCity caddy[53878]: runtime.GOOS=linux
Oct 24 12:12:09 TwinCity caddy[53878]: runtime.GOARCH=amd64
Oct 24 12:12:09 TwinCity caddy[53878]: runtime.Compiler=gc
Oct 24 12:12:09 TwinCity caddy[53878]: runtime.NumCPU=8
Oct 24 12:12:09 TwinCity caddy[53878]: runtime.GOMAXPROCS=8
Oct 24 12:12:09 TwinCity caddy[53878]: runtime.Version=go1.17
Oct 24 12:12:09 TwinCity caddy[53878]: os.Getwd=/
Oct 24 12:12:09 TwinCity caddy[53878]: LANG=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_ADDRESS=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_IDENTIFICATION=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_MEASUREMENT=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_MONETARY=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_NAME=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_NUMERIC=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_PAPER=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_TELEPHONE=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: LC_TIME=en_US.UTF-8
Oct 24 12:12:09 TwinCity caddy[53878]: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/snapd/snap/bin
Oct 24 12:12:09 TwinCity caddy[53878]: XDG_DATA_DIRS=/var/lib/flatpak/exports/share:/usr/local/share/:/usr/share/
Oct 24 12:12:09 TwinCity caddy[53878]: _WSREP_START_POSITION=
Oct 24 12:12:09 TwinCity caddy[53878]: HOME=/var/lib/caddy
Oct 24 12:12:09 TwinCity caddy[53878]: LOGNAME=caddy
Oct 24 12:12:09 TwinCity caddy[53878]: USER=caddy
Oct 24 12:12:09 TwinCity caddy[53878]: INVOCATION_ID=01bd0a224a5c4306a41508ea36feeb1d
Oct 24 12:12:09 TwinCity caddy[53878]: JOURNAL_STREAM=8:207509
Oct 24 12:12:09 TwinCity caddy[53878]: SYSTEMD_EXEC_PID=53878
Oct 24 12:12:09 TwinCity caddy[53878]: XDG_DATA_HOME=/var/lib
Oct 24 12:12:09 TwinCity caddy[53878]: XDG_CONFIG_HOME=/etc
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.800548,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"warn","ts":1635095529.8010812,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8022342,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.80231,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8023193,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8023744,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00053c460"}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8024924,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["filthy.pictures"]}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8025265,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy"}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8026655,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/autosave.json"}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8026764,"msg":"serving initial configuration"}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8027651,"logger":"tls.obtain","msg":"acquiring lock","identifier":"filthy.pictures"}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.8028321,"logger":"tls","msg":"finished cleaning storage units"}
Oct 24 12:12:09 TwinCity caddy[53878]: {"level":"info","ts":1635095529.804803,"logger":"tls.obtain","msg":"lock acquired","identifier":"filthy.pictures"}
Oct 24 12:12:10 TwinCity caddy[53878]: {"level":"info","ts":1635095530.1754358,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["filthy.pictures"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":""}
Oct 24 12:12:10 TwinCity caddy[53878]: {"level":"info","ts":1635095530.1755018,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["filthy.pictures"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":""}
Oct 24 12:12:10 TwinCity caddy[53878]: {"level":"info","ts":1635095530.304622,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"filthy.pictures","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Oct 24 12:12:10 TwinCity caddy[53878]: {"level":"info","ts":1635095530.6410556,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"filthy.pictures","challenge":"http-01","remote":"18.222.145.89:46090","distributed":false}
Oct 24 12:12:10 TwinCity caddy[53878]: {"level":"info","ts":1635095530.7241101,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"filthy.pictures","challenge":"http-01","remote":"3.67.34.92:22208","distributed":false}
Oct 24 12:12:10 TwinCity caddy[53878]: {"level":"info","ts":1635095530.7909553,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"filthy.pictures","challenge":"http-01","remote":"34.219.64.153:11992","distributed":false}
Oct 24 12:12:10 TwinCity caddy[53878]: {"level":"info","ts":1635095530.961607,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"filthy.pictures","challenge":"http-01","remote":"66.133.109.36:17534","distributed":false}
Oct 24 12:12:11 TwinCity caddy[53878]: {"level":"info","ts":1635095531.2705374,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/31182708/845888548"}
Oct 24 12:12:14 TwinCity caddy[53878]: {"level":"info","ts":1635095534.015133,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":1,"first_url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/fab3a04691f81b7e184f3fd79afb7a7d927e"}
Oct 24 12:12:14 TwinCity caddy[53878]: {"level":"info","ts":1635095534.0154188,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"filthy.pictures"}
Oct 24 12:12:14 TwinCity caddy[53878]: {"level":"info","ts":1635095534.0154288,"logger":"tls.obtain","msg":"releasing lock","identifier":"filthy.pictures"}
Oct 24 12:26:35 TwinCity caddy[53878]: {"level":"error","ts":1635096395.721754,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 12:39:00 TwinCity caddy[53878]: {"level":"error","ts":1635097140.8797295,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 12:47:53 TwinCity caddy[53878]: {"level":"error","ts":1635097673.9903932,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 13:15:58 TwinCity caddy[53878]: {"level":"error","ts":1635099358.9045045,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 13:42:52 TwinCity caddy[53878]: {"level":"error","ts":1635100971.9999073,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 14:14:36 TwinCity caddy[53878]: {"level":"error","ts":1635102876.0873759,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 15:19:17 TwinCity caddy[53878]: {"level":"error","ts":1635106757.6452563,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 15:21:02 TwinCity caddy[53878]: {"level":"error","ts":1635106862.5702853,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 15:50:24 TwinCity caddy[53878]: {"level":"error","ts":1635108624.3859866,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 16:09:44 TwinCity caddy[53878]: {"level":"error","ts":1635109784.9891996,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 16:12:02 TwinCity caddy[53878]: {"level":"error","ts":1635109922.015979,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 16:14:52 TwinCity caddy[53878]: {"level":"error","ts":1635110092.7527184,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:04:45 TwinCity caddy[53878]: {"level":"error","ts":1635113085.010954,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:22:15 TwinCity caddy[53878]: {"level":"error","ts":1635114135.2557843,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:25:18 TwinCity caddy[53878]: {"level":"error","ts":1635114318.470276,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:25:18 TwinCity caddy[53878]: {"level":"error","ts":1635114318.6145294,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:28:39 TwinCity caddy[53878]: {"level":"error","ts":1635114519.9970846,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:35:40 TwinCity caddy[53878]: {"level":"error","ts":1635114940.3969002,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:36:02 TwinCity caddy[53878]: {"level":"error","ts":1635114962.348431,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:37:55 TwinCity caddy[53878]: {"level":"error","ts":1635115075.6054077,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:38:47 TwinCity caddy[53878]: {"level":"error","ts":1635115127.57747,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:40:31 TwinCity caddy[53878]: {"level":"error","ts":1635115231.693247,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:41:22 TwinCity caddy[53878]: {"level":"error","ts":1635115282.3370697,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:45:27 TwinCity caddy[53878]: {"level":"error","ts":1635115527.4046974,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:47:55 TwinCity caddy[53878]: {"level":"error","ts":1635115675.2892206,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:48:07 TwinCity caddy[53878]: {"level":"error","ts":1635115687.311823,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:48:31 TwinCity caddy[53878]: {"level":"error","ts":1635115711.8815198,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:52:55 TwinCity caddy[53878]: {"level":"error","ts":1635115975.399609,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:53:38 TwinCity caddy[53878]: {"level":"error","ts":1635116018.5167673,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:53:49 TwinCity caddy[53878]: {"level":"error","ts":1635116029.543505,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 17:55:44 TwinCity caddy[53878]: {"level":"error","ts":1635116144.9539,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
Oct 24 19:35:54 TwinCity caddy[53878]: {"level":"error","ts":1635122154.864844,"logger":"tls.issuance.acme","msg":"looking up info for HTTP challenge","host":"filthy.pictures","error":"no information found to solve challenge for identifier: filthy.pictures"}
- Verified on Google Domains that A record was updated via ddclient to point to my IP
- Verified ports were forwarded in Google Fiber router config
- I was succesful once with only http:// (specified in caddyfile) on making filthy.pictures go to Jellyfin. However upon trying again just now it still won’t connect even with http:// only.
- I tried deleting the local files and trying again a couple times, which was stupid, and I believe i hit a rate limit, so you can see from my caddyfile I am currently using the staging
idk sorry
