Cant get caddy + FPM to work
Hello,
i have a Symfony project and wanted to switch from nginx to caddy because of te easyness of the ssl certificates, but i can’t get it to work, i’m just getting 404. But with nginx, it is working. I think both configs are very similar and i don’t understand why it is not working with caddy.
Using Docker
a. Caddy:
docker-compose.yml
version: '3.3'
    image: caddy:2.7
      - './Caddyfile:/etc/caddy/Caddyfile'
      - "443:443/udp"
  default:
    external: true
Caddyfile
projectdomain {
        root * /app/public
        encode zstd gzip
        php_fastcgi php-fpm:9000 {
                resolve_root_symlink
        @phpFile {
                path *.php*
        error @phpFile "Not found" 404
b. Nginx:
docker-compose.yml
version: '3.3'
  nginx:
      image: nginx:1.25.2-alpine3.18
      container_name: nginx
          - "8034:80"
          - ./nginx.conf:/etc/nginx/conf.d/default.conf
  default:
    external: true
nginx.conf
server {
    listen 80;
    server_name localhost;
    root /app/public;
    location / {
        try_files $uri /index.php$is_args$args;
    location ~ ^/index\.php(/|$) {
        fastcgi_pass php-fpm:9000;
        fastcgi_split_path_info ^(.+\.php)(/.*)$;
        include fastcgi_params;
        fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
        fastcgi_param DOCUMENT_ROOT $document_root;
        internal;
    error_log /var/log/nginx/project_error.log;
    access_log /var/log/nginx/project_access.log;
Note: When i set a wrong fpm host in the Caddyfile, the result is the same.
I set it up using this guide.
Symfony Docs
You need to mount your code to /app in both the Caddy and php-fpm containers.
Why?
nginx is communicating through port 9000 to fpm and it’s working, so i don’t get why caddy should have access to /app while nginx has no access to /app…
I understand your point. I removed file server, now thr 404 is gone and i get an 200, but it is empty. And when i put in a wrong fpm host, it is also 200. So the fpm is not being contacted by caddy i think, but there are no logs.
Caddy’s try_files works slightly differently than Nginx’s. Caddy’s requires the file to exist on disk for the last entry (e.g. index.php) but nginx allows it to not exist on disk and rewrites to that anyway.
Caddy needs to see the PHP files to know how to rewrite to them, and for file_server to work to serve your static assets.
Thank you very much. So there is no easy solution to this?
The easy solution is to mount your files to your Caddy container. That’s not difficult at all. That’s what everyone who uses Caddy + PHP does.
