Ubuntu 20.04 / obtained from Caddy download site / systemd to manage service
not applicable / run via systemd at startup
# caddy.service
# for your installation.
reticulum.us www.reticulum.us broken.works {
reverse_proxy * 192.168.9.23:80
checkwithscience.com {
reverse_proxy * 192.168.9.40:80
directory.broken.works {
reverse_proxy * 192.168.9.24:80
git.reticulum.us {
reverse_proxy * 192.168.9.35:443 {
tls_insecure_skip_verify
manage.broken.works {
reverse_proxy * 192.168.9.10:8006 {
cepheii.reticulum.us {
reverse_proxy * 192.168.9.22:8112
registry.broken.works {
reverse_proxy * 192.168.9.20:8080
bwarv.broken.works {
reverse_proxy * 192.168.9.80:443 {
keep.bwarv.broken.works {
reverse_proxy * 192.168.9.81:25107
download.bwarv.broken.works {
reverse_proxy * 192.168.9.81:9002
collections.bwarv.broken.works {
*.collections.bwarv.broken.works {
ood.broken.works {
reverse_proxy * 192.168.9.200:80
I have been reading through the documentation and I simply cannot grok what we are supposed to do to get DNS-01 challenges working for wildcard certs with Letsencrypt. I have gotten so far as installing the custom build for Route53 and creating an IAM user with the appropriate policies for the hosted zone, but the “example” directive is missing information. The Github documentation shows you this to put into your Caddyfile:
dns route53 {
max_retries 10
aws_profile "real-profile"
But there is no indication as to
- Where in the Caddyfile this directive goes
- Where it is supposed to get an AWS profile from
I’m kind of theorizing that in my example Caddyfile it would be something like this, putting the “tls” directive at the same level as the “reverse_proxy” directive:
dns route53 {
max_retries 10
aws_profile "wildcard-user"
But even assuming that is true, I have no idea what to do next. How is it supposed to know what “wildcard-user” is? Why can’t I just specify a path to a file with the credentials in it?
Thanks in advance for any help.
