Can't figure out caddy as reverse proxy for filebrowser
I have home server with network IP 192.168.1.102
I’m running Filebrowser on my home server on port 8081
I want to use caddy on same machine as reverse proxy to add HTTPS support
I have dyndns setup for my dynamic ip.
Both 8081 and 8089 are port forwarder on home router.
I was trying to setup caddy on 8089 port.
The certificate issuing didn’t work until I opened portforwarded ports 80 and 443. The router informed me the web access port will be moved to 8080.
As I understand from reading the forums I can’t use a custom HTTPS port with external certificate authorities? Am I correct?
2024/10/27 10:45:01.541 ERROR   http.log.error  dial tcp: lookup --from: no such host   {"request": {"remote_ip": "192.168.1.1", "remote_port": "3256", "client_ip": "192.168.1.1", "proto": "HTTP/2.0", "method": "GET", "host": "murmur.hopto.org", "uri": "/", "headers": {"Cache-Control": ["max-age=0"], "Sec-Ch-Ua": ["\"Chromium\";v=\"130\", \"Google Chrome\";v=\"130\", \"Not?A_Brand\";v=\"99\""], "Sec-Ch-Ua-Mobile": ["?0"], "Sec-Fetch-Site": ["none"], "Dnt": ["1"], "Sec-Fetch-Mode": ["navigate"], "Accept-Language": ["en-US,en-GB;q=0.9,en;q=0.8,hr-HR;q=0.7,hr;q=0.6"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/130.0.0.0 Safari/537.36"], "Sec-Fetch-User": ["?1"], "Priority": ["u=0, i"], "Accept-Encoding": ["gzip, deflate, br, zstd"], "Sec-Ch-Ua-Platform": ["\"Windows\""], "Upgrade-Insecure-Requests": ["1"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"], "Sec-Fetch-Dest": ["document"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "murmur.hopto.org"}}, "duration": 2.7024262, "status": 502, "err_id": "k3uavt5ea", "err_trace": "reverseproxy.statusError (reverseproxy.go:1269)"}
Copied to C:\Programs and executed caddy run
Windows 11
murmur.hopto.org {
	reverse_proxy --from :443 --to :8081
That’s not valid syntax. You used the CLI syntax (like when you run commands in your terminal), not Caddyfile syntax.
You want reverse_proxy localhost:8081
I don’t think --from and --to are valid in Caddyfile, only on the command line.
Snap, @francislavoie :slight_smile:
OK, I started
caddy reverse-proxy --from :443 --to :8081
without caddyfile
This site can’t provide a secure connection
murmur.hopto.org sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
Then I started
with Caddyfile
murmur.hopto.org {
This seems to work. It opened the webpage.
Now my question is can I put two web servers and have caddy direct correctly? I can’t use different ports for HTTPS?
Yes. But for that, subdomains are recommended.
You can use different ports for HTTPS, but that’s the worst option. Using subdomains is better because you have an actual name you can type instead of a number.
