Can't curl outside of localhost on LAN
2.4.3
Caddyfile
Arch linux, native, systemd
caddy reload
:2015
respond "Hello World"
I’m trying to access this server from another computer using
curl https://192.168.0.183:2015
curl 192.168.0.183:2015
curl: (28) Failed to connect to 92.168.0.193 port 80 after 131415 ms: Connection timed out
I tried localhost instead of :2015
Also tried:
caddy file-server -browse
this worked fine
have trouble connecting with -domain and going to said domain, I have done port forwarding on ports 80 and 443
sudo caddy file-server -browse -domain gnupluslinux.club
I’m confused. You’re talking about both ports 2015 and 80/443 at the same time.
Could you try explaining the problem again? Please be as detailed as possible.
I got something like this to “work”
example.com {
  respond "hello"
But the issue I’m having right now is that I can’t access it on LAN but WAN works fine.
The issue is listed here Using Caddy as a reverse proxy in a home network and the solution is to make DNS which I’m going to do now
Solved my Issue. I apologize for being confusing.
What was your issue, ultimately?
It’s good forum etiquette to explain, so that future visitors that might land on this post don’t get left hanging with no conclusion.
My issue was that my router doesn’t support hairpin NAT.
