Im trying to setup UpSnap for my homelab in order to use it to start some devices like my NAS remotely. Hoewever, I’m struggling with integrating it with Caddy. I have deployed Caddy as well as all my services using Docker with them all being in the same network. This works great, but I need to run UpSnap with network-mode set to host as otherwise sending the WOL magic packets won’t work. Now I can’t access the UpSnap container from my Caddy container. Any help or alternative solutions would be welcome! Thanks!
"level": "error",
"ts": 1719072621.3118887,
"logger": "http.log.error",
"msg": "dial tcp 172.17.0.1:8090: i/o timeout",
"request": {
"remote_ip": "172.18.0.1",
"remote_port": "58399",
"client_ip": "172.18.0.1",
"proto": "HTTP/2.0",
"method": "GET",
"host": "upsnap.ts.krimphove.site",
"uri": "/",
"headers": {
"Sec-Fetch-Dest": ["document"],
"Dnt": ["1"],
"Sec-Gpc": ["1"],
"Te": ["trailers"],
"User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:127.0) Gecko/20100101 Firefox/127.0"],
"Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],
"Accept-Language": ["en-GB,en;q=0.5"],
"Upgrade-Insecure-Requests": ["1"],
"Priority": ["u=1"],
"Accept-Encoding": ["gzip, deflate, br, zstd"],
"Sec-Fetch-Mode": ["navigate"],
"Sec-Fetch-Site": ["none"],
"Sec-Fetch-User": ["?1"]
"tls": {
"resumed": false,
"version": 772,
"cipher_suite": 4867,
"proto": "h2",
"server_name": "upsnap.ts.krimphove.site"
"duration": 3.002459921,
"status": 502,
"err_id": "zx82vjgb8",
"err_trace": "reverseproxy.statusError (reverseproxy.go:1269)"
v2.8.4
Running it on a Raspberry Pi (Ubuntu Server 24.04 LTS) inside a Docker container using docker compose. All my devices including the pi are on a Tailscale tailnet and the I have a wildcard DNS entry pointing to the tailnet ip of the pi.
docker compose up -d
dockerfile:
FROM caddy:2.8.4-builder AS caddy-builder
RUN xcaddy build \
FROM caddy:2.6.1-alpine
COPY --from=caddy-builder /usr/bin/caddy /usr/bin/caddy
Caddy:
build:
context: ./
dockerfile: dockerfile
image: caddy:cloudflare
- 443:443
- caddy
- caddy_data:/data
- caddy_config:/config
extra_hosts:
- host.docker.internal:host-gateway
caddy_data:
caddy_config:
external: true
UpSnap:
upsnap:
container_name: upsnap
image: ghcr.io/seriousm4x/upsnap:latest
network_mode: host
- ./data:/app/pb_data
- TZ=Europe/Berlin
(cloudflare) {
dns cloudflare <key>
# whoami
whoami.ts.krimphove.site {
reverse_proxy whoami:80
import cloudflare
# upsnap
upsnap.ts.krimphove.site {
reverse_proxy host.docker.internal:8090
import cloudflare
- GitHub - seriousm4x/UpSnap: A simple wake on lan web app written with SvelteKit, Go and PocketBase.
- https://www.youtube.com/watch?v=Vt4PDUXB_fg - the tutorial I followed when setting up Caddy
