):2.4.6
Windows 10 Prob. Command:
./caddy run
N/A
sonarr.scottyydg.com {
output file access.log {
roll_size 5MiB
roll_keep_for 168h
roll_keep 2
reverse_proxy /sonarr/* {
to localhost:8989
Basically, Caddy ran fully once, and ever since then it seems to hang on the ‘finished cleaning storage units’ without progressing even after several minutes.
PS C:\Caddy> ./caddy run
2022/01/10 22:18:22.026 ←[34mINFO←[0m using adjacent Caddyfile
2022/01/10 22:18:22.028 ←[33mWARN←[0m input is not formatted with ‘caddy fmt’ {“adapter”: “caddyfile”, “file”: “Caddyfile”, “line”: 2}
2022/01/10 22:18:22.032 ←[34mINFO←[0m admin admin endpoint started {“address”: “tcp/localhost:2019”, “enforce_origin”: false, “origins”: [“localhost:2019”, “[::1]:2019”, “127.0.0.1:2019”]}
2022/01/10 22:18:22.032 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {“cache”: “0xc000252770”}
2022/01/10 22:18:22.032 ←[34mINFO←[0m http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {“server_name”: “srv0”, “https_port”: 443}
2022/01/10 22:18:22.032 ←[34mINFO←[0m http enabling automatic HTTP->HTTPS redirects {“server_name”: “srv0”}
2022/01/10 22:18:22.032 ←[34mINFO←[0m tls cleaning storage unit {“description”: “FileStorage:C:\Users\scott\AppData\Roaming\Caddy”}
2022/01/10 22:18:22.033 ←[34mINFO←[0m http enabling automatic TLS certificate management {“domains”: [“sonarr.scottyydg.com”]}
2022/01/10 22:18:22.043 ←[34mINFO←[0m autosaved config (load with --resume flag) {“file”: “C:\Users\scott\AppData\Roaming\Caddy\autosave.json”}
2022/01/10 22:18:22.043 ←[34mINFO←[0m serving initial configuration
2022/01/10 22:18:22.044 ←[34mINFO←[0m tls finished cleaning storage units
Restarted the machine, ensured the required ports are open, rewritten the config file a few different ways, both basic and verbose, tried to start it directly using --from and --to in the command line
N/A
