run: adapting config using caddyfile: automation policy from site block is also default/catch-all policy because of key without hostname, and the two are in conflict: []certmagic.Issuer{(*caddytls.ACMEIssuer)(0xc00020c600)} != []certmagic.Issuer(nil)
Can you please fill out the template and not redact anything from the Caddyfile (except for API tokens, if any)? This config works fine for me without errors
If you click “New Topic”, you should see a help thread template. Please fill that out completely, as it’s important for us to understand the context for your issue.
