I’m using Lapis (a Lua language web framework) which running on OpenResty server. Can we do the same thing with Caddy? Eg I want to embed Echo/Gin framework into Caddy to achieve some custom logic when matching HTTP routes.
The possibilities are endless, really.
For matching, we have the expression
matcher, which uses CEL, a simple embedded language. You could do something similar with the language of your choice.
Do you have any specific questions?
Is there any sample demonstrating how to integrate a web framework into Caddy? I want to build some custom logic eg aggregate result from multiple API.
Not that I’m aware of. You can take a look at the plugins listed on the Caddy download page and read their source to get some ideas.
