Can not upload Large file to CaddyServer show ‘(failed)net::ERR_CONNECTION_RESET’ after 3minutes.
my file size 300mb +. But when upload low size (40mb±) then work. I identify that when I upload large file then it fail after 3 minutes.
I checked caddy log but no issue found. following message from browser request error message👇
I have run caddy as usual. already running many web app through caddy. This app also running but when I upload large file then issue occur.
Distributor ID: | Ubuntu |
Description: | Ubuntu 22.04.1 LTS |
Release: | 22.04 |
Codename: | jammy |
m.besnik.net {
root * /var/www/m.besnik.net/public
# Provide Zstd and Gzip compression
encode zstd gzip
# Enable PHP-FPM
# Change this based on installed php version
php_fastcgi unix//run/php/php8.1-fpm.sock
# Allow caddy to serve static files
output file /var/log/caddy/flowgiri.access.log
@static {
file
header @static Cache-Control max-age=5184000
