official systemd unit from the github repo, no alterations
ubuntu 18.04 lts, systemd controlled start
systemctl start caddy
official service unit from github
(gen) {
try_files {path} {path}.html
php_fastcgi unix//var/run/php/php7.4-fpm.sock
handle_errors {
rewrite * /{http.error.status_code}
reverse_proxy https://http.cat {
header_up Host http.cat
format console
output file /var/log/caddy.log {
roll_size 25mb
roll_keep 20
roll_keep_for 720h
(dns) {
dns digitalocean redacted lol
(header-gen) {
Strict-Transport-Security "max-age=31536000; includeSubdomains; preload"
X-Frame-Options "DENY"
eiphax.tech {
Strict-Transport-Security "max-age=31536000; preload"
root * /var/www/eipdox
import gen
facts.eiphax.tech {
import header-gen
root * /var/www/eipdox/facts
import gen
soultrader.net.au {
import header-gen
root * /var/www/st
import gen
blog.eiphax.tech {
import header-gen
root * /var/www/blog
import gen
album.eiphax.tech {
import header-gen
root * /var/www/lychee/public
import gen
bin.eiphax.tech {
import header-gen
root * /var/www/eipbin
import gen
3ds.eiphax.tech {
import header-gen
root * /var/www/eipdox/3ds
import gen
http://wiiu.eiphax.tech {
root * /var/www/eipdox/wiiu
import gen
https://wiiu.eiphax.tech {
import gen
nx.eiphax.tech {
import header-gen
root * /var/www/eipdox/nx
import gen
nintendohomebrew.com {
root * /var/www/eipdox/nh
import gen
http://bhax.nintendohomebrew.com {
root * /var/www/bhax/web/nbhax
bfm.nintendohomebrew.com {
import header-gen
root * /var/www/eipdox/nh/seed
reverse_proxy localhost:8082
handle_errors {
level error
format console
output file /var/log/bfm_error.log {
roll_size 25mb
roll_keep 20
roll_keep_for 720h
http://part1dumper.nintendohomebrew.com https://part1dumper.nintendohomebrew.com {
reverse_proxy localhost:8081
shitpost.lol {
import header-gen
root * /var/www/sp
import gen
hacc.me please.hacc.me {
import header-gen
root * /var/www/hacc
import gen
friigaemsworld.com {
import header-gen
root * /var/www/frigam
import gen
uwu.tax {
import header-gen
root * /var/www/uwu
import gen
conversation.id {
import header-gen
root * /var/www/conv
import gen
puebes.com {
import header-gen
root * /var/www/puebes
import gen
not a problem, per se, but i’m wanting to see if i can intercept an incoming request for example.com/foo/bar.png, check the referrer (which caddy already seems to capture based on logs), and if referrer = foo, serve foo.png from the same directory, if referrer = any other, serve bar.png as originally requested
nothing, yet… i’ve had a look at rewrite and uri, but they don’t seem to have the “if > then” that i think i need. i’ve also looked at placeholders, and i guess i’d be using {header.Referer} but i don’t know how to actually implement what i’m thinking here.
