v2.0.0
Operating System: Ubuntu 18.04.4 LTS
Kernel: Linux 4.15.0-140-generic
Architecture: x86-64
caddy start
# caddy.service
# for your installation.
a******.d***********.net {
root * /var/www/organizr.local/html
php_fastcgi unix//run/php/php8.0-fpm.sock
rewrite /api/v2/* /api/v2/index.php?{query}
reverse_proxy /ombi* 127.0.0.1:5000
reverse_proxy /tautulli* 127.0.0.1:8181
reverse_proxy /nzbget* 127.0.0.1:6789
reverse_proxy /transmission* 127.0.0.1:9091
reverse_proxy /nzbhydra2* 127.0.0.1:5076
reverse_proxy /radarr* 127.0.0.1:7878
reverse_proxy /jackett* 127.0.0.1:9117
reverse_proxy /bazarr* 127.0.0.1:6767
reverse_proxy /sonarr* 127.0.0.1:8989
reverse_proxy /calibre* 127.0.0.1:8083
I want to run calibre-web on reverse proxy /calibre location like other services which i have. Other services works on SSL without any problem. But when i go to a******.d***********.net/calibre
url, it gives:
Calibre-Web
Error 404
Not Found
No specific output.
