‘’’ I had to reinstall Calibre-Web and used a full VM instead of my container (which it was working on previously). I can access it via VPN/IP address, however, I can’t connect it via DNS behind caddy. Was wondering if anyone knows what might be the hangup. Other services such as Nextcloud are currently resolving just fine.‘’’
May 01 19:21:22 Caddy caddy[139]: USER=caddy
May 01 19:21:22 Caddy caddy[139]: INVOCATION_ID=eef2611ef58b4fd38db8b5f3fe1d4bc6
May 01 19:21:22 Caddy caddy[139]: JOURNAL_STREAM=9:345528717
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.0369937,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
May 01 19:21:22 Caddy caddy[139]: {"level":"warn","ts":1682968882.043112,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":12}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.047752,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.050886,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0000c7c00"}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.0515363,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.052577,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.0563369,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.0640976,"logger":"tls","msg":"finished cleaning storage units"}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.064598,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
May 01 19:21:22 Caddy caddy[139]: {"level":"info","ts":1682968882.0656855,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0000c7c00"}
May 01 19:21:22 Caddy caddy[139]: Error: loading initial config: loading new config: http app module: start: listen udp :443: bind: address already in use
May 01 19:21:22 Caddy systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
May 01 19:21:22 Caddy systemd[1]: caddy.service: Failed with result 'exit-code'.
May 01 19:21:22 Caddy systemd[1]: Failed to start Caddy.
Installed via the instructions on the website
Ubuntu 22.04 container running via Proxmox
Caddy runs at bootup
calibre.sampledomain.com {
reverse_proxy 192.168.1.106:8083 {
header_up X-Scheme https
