CaddyV2 in docker able to resolve some docker containers by hostname but not others
Whatever the caddy image being pulled by the below docker compose:
Docker
Raspberry Pi 3 with Docker.
version: "3.8"
    image: caddy
    hostname: caddy
    env_file: ../.env
      - DOMAIN
      - DOMAIN_LOCAL
      - ./data:/data
      - ./config:/config
  default:
    external:
portainer.{$DOMAIN} portainer.{$DOMAIN_LOCAL} {
    reverse_proxy portainer:9000
home.{$DOMAIN} home.{$DOMAIN_LOCAL} {
    reverse_proxy homeassistant:8123
When i replace homeassistant with 192.168.1.100 (which is the local IP of the Raspberry Pi running caddy, portainer, and home assistant docker containers) in the home. route the caddy reverse proxy works perfect and resolves to the home assistant docker container.
But the portainer:9000 works fine! It perfectly routes the portainer. subdomian to the docker container on the Pi.
Here is my docker-compose for portainer which works great with the caddyFile
version: '3.8'
  portainer:
    image: portainer/portainer
    container_name: portainer
    hostname: portainer
    env_file: ../.env
    command: -H unix:///var/run/docker.sock
      - ./data:/data
  default:
    external:
Here is my homeassistant docker-compose:
version: '3.8'
  homeassistant:
    image: homeassistant/raspberrypi3-homeassistant:stable
    container_name: homeassistant
    hostname: homeassistant
    env_file: ../.env
    network_mode: host # exposes all ports, needed for multicast DNS
    restart: always
      - ./config:/config
    devices:
      - /dev/ttyUSB0:/dev/ttyUSB0:rwm
      - /dev/ttyUSB1:/dev/ttyUSB1:rwm
  default:
    external:
As you can see they are both connected to the same docker network which i have created externally and both reference using the the same .env file.
502 bad gateway when i try to use homeassistant:8123 instead of 192.168.1.100:8123.
I have found out that putting the local IP works, this doesn’t seem to be caused by home assistant because keeping it’s config the same and changing the reverse proxy route works.
Is this due to the network_mode: host?
Probably, yes. I think the homeassistant container won’t exist in the network Caddy is in, so it won’t be able to connect. So you’ll need to use the host IP to connect to it, I guess.
I’m sure others have run into a similar issue with homeassistant, this isn’t something specific to Caddy, really. It’s more of a general Docker thing.
My bad, thank you for the information! I 'll ask around on the docker forums. But it looks like this might be the culprit since i think network_mode: host makes it impossible for a container to be on a docker network.
Thanks again! Caddy Rules!!! SOOOOO much easier than nginx and automatic HTTPS is. dream :heart_eyes:
