CaddySSL is still not generating RSA keys instead of EC Kesy
Hello Mr. Matt,
It’s still not generated RSA key file instead of EC key, even though I added below code to my Caddyfile.
    key_type rsa2048
And my Caddyfile is now as below…
mydomain.com
  reverse_proxy 127.0.0.1:5000`
   key_type rsa2048
Please help me. Thank you in advance!
Paste command here.
        "sans": [
                "mydomain.com"
        "issuer_data": {
                "url": "https://acme-v02.api.letsencrypt.org/acme/cert/04---aee8f5-----a3e83c--acafbf5"
Paste config here, replacing this text.
Use caddy fmt to make it readable.
LEAVE DOMAIN NAMES INTACT.
### 3. The problem I'm having:
<!-- What are you trying to do, and what isn't working? Please describe the issue thoroughly enough so that anyone can reproduce the exact behavior you're seeing. Be as specific as possible. DO NOT USE WEB BROWSERS; use "curl -v" instead. -->
-----BEGIN EC PRIVATE KEY-----
MHcCAQEEIMnb5yhMoHQkhZlglH94c2wLE9SBh2YX+MaK76lx+3/YoAoGCCqGSM4
### 4. Error messages and/or full log output:
<!-- Please **DO NOT REDACT** any information except credentials. Leave domain names intact! -->
<!-- Please **DO NOT POST TRUNCATED LOG LINES** as systemd is notorious for this. -->
<!-- Please **DO NOT USE WEB BROWSERS.** Use curl -v instead. -->
<!-- Please **DO ENABLE DEBUG MODE FIRST** by adding "debug" to the global options of your Caddyfile. -->
### 5. What I already tried:
<!-- Show us what effort you've put in to solving the problem. Be specific -- people are volunteering their time to help you! Low effort posts are not likely to get good answers! -->
### 6. Links to relevant resources:
Please see how the Caddyfile is structured:
Directives go within site blocks, not outside.
Next time, please properly follow the topic template, and do not ignore any sections.
Super Sir,
It’s working very wonderfully more than my expectations with the same CaddySSL after I made a change to it.
A Heartfelt thanks to Mr.Matt for his straight solution and you too!
Hi Sir,
I have added 3 mx records under DNS zones for MTA-STS. I’ve been struggling a lot to enable MTA-STS for my website. But, it’s still seems to be wrong.
So could you please let me have your guidance on how to make it done in a right way since I used in below lines in my Caddyfile and nothing worked for me.
mydoamin.com
 tls....{ ....}
mta-sts.mydomain.com {
respond "version: STSv1
mode: testing
mx: mail.mydomain.com
max_age: 86401"
header Content-Type "text/plain; charset=utf-8"
Many thanks in advance for your quick response.!
Kind Regards,
Xeny
Hello,
Can anyone help me with a solution for this, please? Thank you in advance!
