2.4.5
Docker
Docker
docker-compose up -d
docker exec -w /etc/caddy caddy caddy validate
version: "3.7"
image: caddy
hostname: caddy
- MY_DOMAIN
- ./data:/data
- ./config:/config
default:
external:
vaultwarden.{$MY_DOMAIN} {
reverse_proxy vaultwarden:80
portainer.{$MY_DOMAIN} {
reverse_proxy portainer:9000
I dont have a problem and everything works, just curious, because it throws warning when doing graceful reload / or validating Caddyfile. Just for education purposes.
│ {“level”:“info”,“ts”:1632171529.1133611,“msg”:“using provided configuration”,“config_file”:"/etc/caddy/Caddyfile",“config_adapter”:“caddyfile”} │
│ {“level”:“warn”,“ts”:1632171529.118295,“msg”:“input is not formatted with ‘caddy fmt’”,“adapter”:“caddyfile”,“file”:"/etc/caddy/Caddyfile",“line”:2} │
│ {“level”:“info”,“ts”:1632171529.1271234,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“tcp/localhost:2019”,“enforce_origin”:false,“origins”:[“localhost:2019”,"[::1]:2019",“127.0.0.1:2019”]} │
│ {“level”:“info”,“ts”:1632171529.1305757,“logger”:“http”,“msg”:“server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS”,“server_name”:“srv0”,“https_port”:443} │
│ {“level”:“info”,“ts”:1632171529.1307333,“logger”:“http”,“msg”:“enabling automatic HTTP->HTTPS redirects”,“server_name”:“srv0”} │
│ {“level”:“info”,“ts”:1632171529.131466,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0x4000112070”} │
│ {“level”:“info”,“ts”:1632171529.132646,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/data/caddy”} │
│ {“level”:“info”,“ts”:1632171529.1332653,“logger”:“http”,“msg”:“enabling automatic TLS certificate management”,“domains”:[“vaultwarden.REDACTED”,“portainer.REDACTED”]} │
│ {“level”:“info”,“ts”:1632171529.139218,“logger”:“tls”,“msg”:“finished cleaning storage units”} │
│ {“level”:“info”,“ts”:1632171529.1403375,“msg”:“autosaved config (load with --resume flag)”,“file”:"/config/caddy/autosave.json"} │
│ {“level”:“info”,“ts”:1632171529.1405272,“msg”:“serving initial configuration”}
I dont know what should I do to suppress this warning.
