./caddy version
v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
APPPORT=:8888 ./caddy run -config docker-files/opt/webroot/config/Caddyfile
# or
APPPORT=:8888 ./caddy run -adapter jsonc -config config/Caddyfile-upload.json
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
# or
podman run --rm \
--network host \
--name caddy-test \
--env APPPORT=:8888 \
-it \
--entrypoint /bin/bash \
docker.io/me2digital/caddyv2-upload:0.5
# in the container
# https://github.com/git001/caddyv2-upload/blob/main/docker-files/opt/webroot/config/Caddyfile
order upload before file_server
level DEBUG
{$APPPORT} {
root .
file_server browse
templates
@mypost method POST
upload @mypost {
dest_dir tmp-upl
max_form_buffer 1G
max_filesize 4MB
response_template templates/upload-resp-template.txt
output file access.log
# https://github.com/git001/caddyv2-upload/blob/main/docker-files/opt/webroot/config/Caddyfile-upload.json
"admin": {
"listen": "127.0.0.1:8081"
"apps": {
"http": {
"grace_period": "30m",
"servers": {
"example": {
"listen": ["{env.APPPORT}"],
"logs": {
"default_logger_name": "myaccesslogger"
"routes": [
"match":[
"method": ["GET"],
"path": ["/print-headers-template.txt"]
"handle": [
"handler": "templates"
"handler": "headers",
"response": {
"set": {
"Content-Type": ["text/plain; charset=utf-8"]
"handler": "file_server",
"root": "templates"
"match":[
"method": ["GET"],
"path": ["/upload-template.html"]
"handle": [
"root": "templates"
"match":[
"method": ["GET"]
"handle": [
"browse":
"match":[
"method": ["POST"]
"handle": [
"response": {
"set": {
"handler": "upload",
"dest_dir": "tmp-upl",
"max_filesize": 1024000,
"response_template":"upload-resp-template.txt"
"root": "templates"
"logging": {
"logs": {
"default": {
"level": "INFO"
"myaccesslogger": {
"writer": {
"output": "stdout"
"encoder": {
"format": "json"
I would like to configure in the Caddyfile-upload.json also the “max_filesize 4MB” similar to the Caddyfile and that via “{env.MAXFILESIZE}” is this possible or do I need to use a own adapter for this?
I tried to use ““max_filesize”: “{env.MAXFILESIZE}”” but got a json parsing error.
