Caddyfile syntax highlighting with Prism
Not sure if this belongs here, but here goes. I wanted syntax highlighting in my Markdown blog, so I used Prism, This doesn’t include highlighting for Caddyfiles so I added a custom definition. Perhaps this will be useful for someone else.
import 'prismjs';
import Prism from 'prismjs';
Prism.languages['caddyfile'] = {
    comment: /#.*/,
    string: {
        pattern: /"(?:\\.|[^"\\])*"|`(?:\\.|[^`\\])*`/,
        greedy: true,
    matcher: {
        pattern: /@[A-Za-z0-9_-]+/,
        alias: 'function',
    placeholder: {
        pattern: /\{[^{}\s]+}/,
        alias: 'variable',
    address: {
        pattern: /(?:localhost|(?:\*\.)?(?:[A-Za-z0-9-]+\.)+[A-Za-z]{2,}|\*:)\S*/,
        alias: 'symbol',
    directive: {
        pattern: /\b(?:abort|acme_server|basicauth|bind|encode|error|file_server|forward_auth|handle|handle_errors|handle_path|header|import|log|map|method|metrics|php_fastcgi|redir|request_body|request_header|respond|reverse_proxy|rewrite|root|route|templates|tls|try_files|uri|vars)\b/,
        alias: 'keyword',
    boolean: /\b(?:true|false|on|off)\b/,
    number: /\b\d+(?:\.\d+)?\b/,
    punctuation: /[{}()[\],]/,
Prism.languages['caddy'] = Prism.languages['caddyfile'];
See it in action here: Add syntax highlighting to Markdown - PhotoPaste
Wonderful, thank you for sharing!
