Within the past 2 days, the reverse proxy I had set up for my media server via the Caddyfile “reverse_proxy” directive is no longer working.
Excerpt of output (parts I thought would be relevant) since pasting all output after “Started Caddy” line exceeded post character limit.
Dec 31 12:25:42 ubuntu-pc caddy[1140]: {"level":"error","ts":1704043542.7140281,"logger":"http.acme_client","msg":"challenge failed","identifier":"mydnsname.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"97.70.224.137: Fetching http://mydnsname.com/.well-known/acme-challenge/Pch-0_839TcTv1Pj-dzLIApgUGhv6S2zpdyzlU2PXdA: Timeout during connect (likely firewall problem)","instance":"","subproblems":[]}}
Dec 31 12:25:42 ubuntu-pc caddy[1140]: {"level":"error","ts":1704043542.7140665,"logger":"http.acme_client","msg":"validating authorization","identifier":"mydnsname.com","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"97.70.224.137: Fetching http://mydnsname.com/.well-known/acme-challenge/Pch-0_839TcTv1Pj-dzLIApgUGhv6S2zpdyzlU2PXdA: Timeout during connect (likely firewall problem)","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/127331144/13341318304","attempt":2,"max_attempts":3}
Dec 31 12:25:42 ubuntu-pc caddy[1140]: {"level":"error","ts":1704043542.714109,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"mydnsname.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:connection - 97.70.224.137: Fetching http://mydnsname.com/.well-known/acme-challenge/Pch-0_839TcTv1Pj-dzLIApgUGhv6S2zpdyzlU2PXdA: Timeout during connect (likely firewall problem)"}
Dec 31 12:25:44 ubuntu-pc caddy[1140]: {"level":"debug","ts":1704043544.0504794,"logger":"http.acme_client","msg":"http request","method":"HEAD","url":"https://acme.zerossl.com/v2/DV90/newNonce","headers":{"User-Agent":["Caddy/2.7.6 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Type":["application/octet-stream"],"Date":["Sun, 31 Dec 2023 17:25:44 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["_BDjpgCaj8agxgyacdrG1V2e5Z4spPpEThkResa-sTc"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":200}
Dec 31 12:25:44 ubuntu-pc caddy[1140]: {"level":"debug","ts":1704043544.906995,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/newOrder","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["282"],"Content-Type":["application/json"],"Date":["Sun, 31 Dec 2023 17:25:44 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/order/LpphbjpY-PJdTeTVXlea9g"],"Replay-Nonce":["5nQ4Gm7nKMQtukZvy32026sBYNp-sLB8MY5OYWn7oy0"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":201}
Dec 31 12:25:45 ubuntu-pc caddy[1140]: {"level":"debug","ts":1704043545.6767008,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/authz/c3gcgRBNVf_4EMHrdsgmSQ","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["300"],"Content-Type":["application/json"],"Date":["Sun, 31 Dec 2023 17:25:45 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["Gea4FLalGDouKVj9W8CLfA57Skor4Qwf_a_5Xi2jNOg"],"Retry-After":["86400"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":200}
Dec 31 12:25:45 ubuntu-pc caddy[1140]: {"level":"error","ts":1704043545.6769145,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"mydnsname.com","issuer":"acme.zerossl.com-v2-DV90","error":"[mydnsname.com] solving challenges: authz https://acme.zerossl.com/v2/DV90/authz/c3gcgRBNVf_4EMHrdsgmSQ has unexpected status; order will fail: invalid (order=https://acme.zerossl.com/v2/DV90/order/LpphbjpY-PJdTeTVXlea9g) (ca=https://acme.zerossl.com/v2/DV90)"}
Dec 31 12:25:45 ubuntu-pc caddy[1140]: {"level":"debug","ts":1704043545.6769593,"logger":"events","msg":"event","name":"cert_failed","id":"da4486ff-555f-4f3a-a1ed-cc2be08047b2","origin":"tls","data":{"error":{},"identifier":"mydnsname.com","issuers":["acme-v02.api.letsencrypt.org-directory","acme.zerossl.com-v2-DV90"],"remaining":-81506650983212,"renewal":true}}
Dec 31 12:25:45 ubuntu-pc caddy[1140]: {"level":"error","ts":1704043545.6769953,"logger":"tls.renew","msg":"will retry","error":"[mydnsname.com] Renew: [mydnsname.com] solving challenges: authz https://acme.zerossl.com/v2/DV90/authz/c3gcgRBNVf_4EMHrdsgmSQ has unexpected status; order will fail: invalid (order=https://acme.zerossl.com/v2/DV90/order/LpphbjpY-PJdTeTVXlea9g) (ca=https://acme.zerossl.com/v2/DV90)","attempt":4,"retrying_in":300,"elapsed":401.608607709,"max_duration":2592000}
v2.7.6
Followed the guide Install — Caddy Documentation for Ubuntu install
Ubuntu 22.04.3 LTS
Kernel: 6.2.0-39-generic
systemd 249 (249.11-0ubuntu3.11)
Running the “reverse-proxy” command as shown below works successfully.
caddy reverse-proxy --from mydnsname.com --to 127.0.0.1:8096
mydnsname.com {
reverse_proxy 127.0.0.1:8096
The reverse proxy was working normally until a day or two ago using the above Caddyfile. The only change made since is the addition of the “debug” global option.
Now, the only way the reverse proxy is working (e.g. allowing access to my media server via https://mydnsname.com) is to stop the Caddy service that runs on system startup
sudo systemctl stop caddy
and manually issue the reverse-proxy command
Seemingly, the command is doing the same thing as the Caddyfile, but the result is different.
