I am trying to install Caddy as a Docker image so I can use it to access other dockers on the same server (e.g. wordpress, osticket, nextcloud etc) by using urls ( wordpress.outsourcedit.co.nz, nextcloud.outsourcedit.co.nz )
I have followed these instructions here.
Every time I tried to access the caddy server ( by url, port, ip number etc) I got connection refused.
After burning 18 hours, hitting every helpfile, system systematically destroying docker, server etc and restarting i have found a way forward. however it still leaves me wondering what was wrong with the initial config and why I need to add extra params to my Caddyfile.
Specifically, without using the :80 directives in my Caddyfile I always got connection refused . With it in I can now curl and get headers etc for pages.
This is the working Caddyfile
auto_https off
respond "hello world 2"
test1.outsourcedit.co.nz {
respond "hello world"
This is the failing Caddyfile
auto_https off
With the directives in place netstat inside my caddy docker looks like:
/srv # netstat -tap
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 localhost:38077 0.0.0.0:* LISTEN -
tcp 0 0 localhost:2019 0.0.0.0:* LISTEN 1/caddy
tcp 0 0 :::http :::* LISTEN 1/caddy
tcp 0 0 :::https :::* LISTEN 1/caddy
/srv #
Without the directives it looks like:
/srv # netstat -tap
tcp 0 0 localhost:38603 0.0.0.0:* LISTEN -
tcp 0 0 localhost:60224 localhost:2019 TIME_WAIT -
Docker Version:
docker-compose pulls as below:
image: caddy
I exactly followed this selfhosted-apps-docker/caddy_v2 at master · DoTheEvo/selfhosted-apps-docker · GitHub
Ubuntu 22.04 server
Docker version 25.0.0, build e758fe5
Server Name: docker01
Hosts File: The docker ip is 172.18.0.3. The hosts ip is 192.168.1.10
172.18.0.3 test1.outsourcedit.co.nz
192.168.1.10 www.test1.outsourcedit.co.nz
docker-compose up -d
cat docker-compose.yml
image: caddy
hostname: caddy
env_file: .env
- "443:443/udp"
- ./caddy_config:/config
- ./caddy_data:/data
default:
external: true
.env file
# GENERAL
TZ=Pacific/Auckland
DOCKER_MY_NETWORK=caddy_net
MY_DOMAIN=outsourcedit.co.nz
Caddyfile
cat Caddyfile
auto_https off
http_port 80
https_port 443
docker network ls
NETWORK ID NAME DRIVER SCOPE
8e7647c500b9 bridge bridge local
5a7e13bcd933 caddy_net bridge local
98eaa8a583cf host host local
928fb8f052b4 none null local
docker network inspect caddy_net
"Name": "caddy_net",
"Id": "5a7e13bcd933a392c84a1a44f0546ea1f06e84c05d1dc85d53e77c88f90371d7",
"Created": "2024-01-20T21:05:32.504534978+13:00",
"Scope": "local",
"Driver": "bridge",
"EnableIPv6": false,
"IPAM": {
"Driver": "default",
"Options": {},
"Config": [
"Subnet": "172.18.0.0/16",
"Gateway": "172.18.0.1"
"Internal": false,
"Attachable": false,
"Ingress": false,
"ConfigFrom": {
"Network": ""
"ConfigOnly": false,
"Containers": {
"c2ea4284020f67c4508fdc756d5b7229ab5fce3bcf809676e39624bc262652cc": {
"Name": "caddy",
"EndpointID": "968285c4308b8123ac13e5a3f98918bfd6498af5d02f3c64c37816d00a9052b9",
"MacAddress": "02:42:ac:12:00:02",
"IPv4Address": "172.18.0.3/16",
"IPv6Address": ""
"ce4baee20fb6da2b05eb9d1599d768b8d042a650dcf8b14f638cacdadfefc32c": {
"Name": "wordpress-db",
"EndpointID": "248962a55ffb359c17dcb3e9bcfde1161c3a648ea93ca0182e434759a9c936ad",
"MacAddress": "02:42:ac:12:00:04",
"IPv4Address": "172.18.0.2/16",
"IPv6Address": ""
"e0ab4fe1045c4f4430e493cb2d87fa9c017803e200f2b979424de6d3b70970c6": {
"Name": "wordpress",
"EndpointID": "079ad053f1f61a7297e4acee75973d698d80a9e9a28d131bc23441b47537c2a1",
"MacAddress": "02:42:ac:12:00:03",
"IPv4Address": "172.18.0.4/16",
"IPv6Address": ""
"Options": {},
"Labels": {}
