Caddyfile for Zabbix?
1. Output of caddy version:
As a systemd service installed following Caddy documentation
Canonical-Ubuntu-22.04-2022.08.10-0
jason@srv:~$ systemctl status caddy
● caddy.service - Caddy
     Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
     Active: active (running) since Tue 2022-11-08 18:04:36 UTC; 2h 38min ago
    Process: 4157 ExecReload=/usr/bin/caddy reload --config /etc/caddy/Caddyfile --force (code=exited>
   Main PID: 3749 (caddy)
      Tasks: 8 (limit: 9451)
     Memory: 8.8M
        CPU: 503ms
             └─3749 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile```
cld.private.com
root * /var/www/html
I’d like to use Caddy instead of Apache or Nginx to serve up Zabbix, I saw another post in Caddy forums that is resolved but the user didn’t post the resulting Caddyfile
N/A
Looks like Zabbix is a PHP application. You’ll need to use php_fastcgi probably.
You should probably follow nginx installation instructions, then just swap in Caddy where they have you install nginx.
You’ll need to have php-fpm set up to run the PHP code I think, which should be covered by nginx installation instructions.
I don’t know whether they use a standard index.php routing setup, but it should just work if they do with the usual pattern of PHP configs in Caddy: Common Caddyfile Patterns — Caddy Documentation
I’m running Zabbix Server behind Caddy; here’s the Caddyfile:
        email admin@domain
        acme_ca https://ca.domain.org/acme/acme/directory
        acme_ca_root /etc/caddy/root_ca.crt
zabbix6.familybrown.org {
                output file /var/log/caddy/zabbix_access.log
        root * /usr/share/zabbix
I’m using a local CA, hence some of the directives in the global block
