Caddyfile for Hugo website with Caddy2
I want to use Caddy2 to show my web site with Hugo
I already create my hugo public folder, this folder’s path is /home/ubuntu/public.
I already install Caddy2
Then I edit the /etc/caddy/Caddyfile for show it.
Here is my Caddyfile
        # root * /usr/share/caddy  ==> default
        # root * /usr/share/pubic   ==> this one work but no https
        root * /home/ubuntu/public  ==> I want to use this one but not working
        # php_fastcgi localhost:9000
I got the 403 error
version is 2.6.4
I follow the official install process.
Linux Ubuntu 22.04
I use caddy reload in the etc/caddy/ folder after I edit the Caddyfile follow blow.
I didn’t use this.
I search with caddy2, root, hugo keywords but didn’t found the solution.
The caddy user doesn’t have permission to read files from other users home directories.
Move your files to /srv or /var/www/html instead and serve them from there.
