Caddyfile for code-server
v2.5.1
I want to run caddy in front of a code-server with a TLS frontend.
Ubuntu 21.10
Using systemd
N/A
code.chrisshort.net {
	uri strip_prefix /code
	reverse_proxy 127.0.0.1:3000
		protocols tls1.2 tls1.3
I had an ssl error and got that fixed. Now I get a timeout. Port 443 on my EdgeRouter forwards to this system’s IP address. I’m really not sure what’s going wrong.
# curl -v https://localhost
*   Trying 127.0.0.1:443...
* Connected to localhost (127.0.0.1) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
* Closing connection 0
I’ve tried a few config snippets but I’m kinda stuck at the moment.
Remove this, it’s redundant. Caddy default to TLS 1.2 as minimum and the maximum that exists currently is TLS 1.3. Having this in your config would prevent a future version of Caddy from being able to automatically enable some theoretical TLS 1.4 if/when that is introduced. Let Caddy do the smart thing.
Are you sure you need this? You already have a code subdomain.
You made a request to localhost but you configured your domain as code.chrisshort.net. Make a request to code.chrisshort.net instead and it should work. You didn’t configure Caddy to serve a certificate for localhost.
Turns out the firewall configuration on my EdgeRouter didn’t take. Traffic to 443 wasn’t being passed to the server. Now it is and everything is working wonderfully.
Thank you!
