Caddyfile failure partly switching to wildcard cert
FreeBSD 12.2-RELEASE-p2 jail inside TrueNAS-12.0-U5.1
service caddy start
	order jwt first
	dynamic_dns {
		provider cloudflare {env.CLOUDFLARE_DYNDNS_API_TOKEN}
		check_interval 1s
		domains {
			my.site home
		ip_source upnp
		ip_source simple_http https://api64.ipify.org
		ip_source simple_http https://api.ipify.org
		ip_source simple_http https://icanhazip.com
(dns) {
		dns cloudflare {env.CLOUDFLARE_DYNDNS_API_TOKEN}
(encoding) {
	encode gzip zstd
(header-sec) {
		# Enable HTTP Strict Transport Security (HSTS) to force clients to always
		# connect via HTTPS (do not use if only testing)
		# Prevent some browsers from MIME-sniffing a response away from the declared Content-Type
		# Disallow the site to be rendered within a frame (clickjacking protection)
		X-Frame-Options SAMEORIGIN
		# Remove Server field
		-Server
		# Upgrade insecure requests
		Content-Security-Policy "upgrade-insecure-requests"
		# Don't include referrer info in requests
		# Referrer-Policy "no-referrer"
(logging) {
		# output stdout
		output file /config/logs/access.{args.0}.log
		# level DEBUG
(primary-auth) {
	@external not remote_ip 192.168.0.0/16
	route @external {
		jwt {
			primary yes
			set auth url https://auth.my.site/auth
			crypto key {env.CADDY_KEY_ID} verify {env.CADDY_SHARED_KEY}
			allow roles allowed
(auth) {
	route @external {
		jwt {
			allow roles allowed
*.my.site {
	import auth
	import dns
	import encoding
	import logging subdomain
	map {host} {upstream} {
		dns https://dns.my.site:443
		duplicati http://duplicati:8200
		homebridge http://homebridge.lan:8080
		ipmi http://ipmi.lan:80
		# nextcloud       nextcloud.my.site.:443
		nas https://nas.my.site:443
		unifi https://unifi.my.site:8443
		default https://proxy.my.site:443
	reverse_proxy {upstream}
proxy.my.site {
	import primary-auth
	import dns
	import encoding
	import logging proxy
	templates
	root * /config/www/home
nextcloud.my.site, cloud.my.site {
	import dns
	import header-sec
	import encoding
	import logging nextcloud
	redir /.well-known/nodeinfo /index.php/nodeinfo 301
	redir /.well-known/webfinger /index.php/webfinger 301
	reverse_proxy https://nextcloud.my.site.:443
auth.my.site {
	import encoding
	import logging auth
	route /auth* {
		authp {
			# path /auth
			cookie domain my.site
			cookie lifetime 3600
			backend google {env.GOOGLE_CLIENT_ID} {env.GOOGLE_CLIENT_SECRET}
			crypto key {env.CADDY_KEY_ID} sign-verify {env.CADDY_SHARED_KEY}
			transform user {
				suffix match email @my.site
				add role allowed
	route /sso/oauth2/google* {
		jwt {
			set auth url /auth/oauth2/google
		respond * "google oauth2 sso" 200
	route /* {
		redir https://{hostport}/auth 302
sale.my.site {
	import dns
	import encoding
	import logging sale
	root * /config/www/sale
# previous solution
# import www/sites/*.caddysite
I’ve long run caddy with several subdomains that I’ve defined in *.caddysite files that has worked well, but I’ve come to realise that the subdomain list is now growing too large to maintain individually, why I figured that switching to a wildcard certificate for them all would work well.
In trying to achieve this, I searched a bit and found this which pointed me toward the map directive.
The problem now though, is that using the caddyfile above doesn’t work for the wildcard domains, surely due to configuration errors on my part.
Switching from the previous method (in part found commented at the end of the caddyfile above) also seems to have screwed with the oAuth stuff. I now receive an Error 401: invalid_client from google upon authentication attempts, and I’m not really sure why.
just holler if there’s any logs that would help
I’ve tried reading the different resources and skimming the logs, but I’m not really getting any wiser.
I’m sure I’ve done something really stupid, please help me sort it out!
Preferrably, I want all of my sites managed under a wildcard cert, but I assume this is hard if at all possible to achieve, but hopefully the amount of separate sites can be minimized.
Also, I’ve tried searching for solutions like this or this for caddy to ”dynamically” log to files named after the current site, but I’m not getting that to work either, and from the reading I’ve done, this can’t be done with placeholders, am I right?
Thanks in advance!
Unfortunately, when using a placeholder for reverse_proxy upstreams, you must not include the scheme (https:// or http://). It must be only the host and port.
If you need to enable TLS, then you’ll need to have a separate reverse_proxy that explicitly enables tls.
	map {host}     {upstream}          {use-tls} {
		dns        dns.my.site:443     yes
		duplicati  duplicati:8200      no
		homebridge homebridge.lan:8080 no
		ipmi       ipmi.lan:80         no
		nas        nas.my.site:443     yes
		unifi      unifi.my.site:8443  yes
		default    proxy.my.site:443   yes
	@proxy-https expression `{use-tls} == "yes"`
	reverse_proxy @proxy-https {upstream} {
			tls
The reason is that the reverse_proxy handler needs to provision a TLS config at startup, and all requests using that handler will use TLS, so to do both HTTP and HTTPS, you need to use two separate handlers.
Basically https:// is a Caddyfile-specific shortcut for enabling TLS (and setting the port to 443 if you didn’t otherwise specify a port) but placeholders are evaluated at runtime, and is separate from the Caddyfile adapter logic.
@adlib The map directive is one of my favourite Caddy commands when dealing with a number of subdomains (or sub-paths). I love the ‘at a glance’ overview it provides me across all subdomains. However, it’s worth noting that coupling map and the upstream services will close off other options that may be of interest at some point e.g. determining the status of upstream servers API — Caddy Documentation. You just need to be aware of this. If those options aren’t going to be of interest, what @francislavoie has suggested works perfectly. For a broader discussion of the issue, and discussion of a hybrid map approach that uses snippets to decouple `map and the upstream servers, refer to Load balancing queries
