I wanted to add today one more reverseproxy destination. The Cadyfile without these lines is running like a charm. I copied just one existing part changed only url and port but it is ending up in an error.
Did I make a silly mistake which I can not see?
After canching Caddyfile with the lines written in post 1 and restarting the container these lines appear in container log and repeating after some seconds
2019/01/18 19:40:09 /etc/Caddyfile:74 - Error during parsing: Unknown directive 'bw.my-wan.de'
exit status 1
It is complaining about the added lines and all others aren’t working …
Is there a letsencrypt limit for for securing domains from a single user?
I guess when the Caddyfile gets parsed, you can put the last site outside of blocks and it’ll parse just fine. The reason you put it in blocks is for this very reason (so the next site doesn’t get interpreted as a directive), so I guess that makes sense.
