2.4.6
docker-compose
caddy run --config /dockerapp/caddy/Caddyfile
storage redis {
host {$REDIS_HOST}
on_demand_tls {
ask 0.0.0.0:3000/domain-check
interval 2m
burst 5
gzip
minify
(SecurityHeaders) {
my-example.com, *.my-example.com {
@notStatic {
not file
reverse_proxy @notStatic web:3000
# format single_field common_log
output file /data/logs/caddy.log
tls my@my-example.com {
dns route53
:443, :80 {
on_demand
Thank you for all your work on Caddy, it’s been great to work with it! I’m migrating over from nginx and there’s one configuration I haven’t been able to add to my Caddyfile:
client_max_body_size which lets you limit the file size of an upload.
There appears to be a way to do it with a JSON, but in this thread it says there wasn’t a way to do it with Caddyfile as of May 2020. File upload size limits
I’d prefer to stick with the Caddyfile format since I’ve spent a lot of time learning this format, and was hoping to use this module without switching to JSON format. Is there a way to accomplish this now?
I tried adding the directives directly into reverse_proxy Caddyfile directive, with no luck.
