I can’t use environment variables as documented here:
If I use it with validation eg. $MY_VAR, caddy will not start as it can’t evaluate the variable.
using {env.MY_VAR} also not working correctly, caddy starts but env variable is not substituted.
$CF_TOKEN:
Unit caddy.service failed to start
{env.CF_TOKEN}:
Certs are simply not updating as cloudflare returns several error messages, mainly "invalid request header"
apt install
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION="Ubuntu 22.04.3 LTS"
# caddy.service
# for your installation.
Type=notify
acme_dns cloudflare REDACTED_API
servers {
import /var/opt/caddy/cloudflare-proxies
email me@tld.org
log default {
output file /var/log/caddy/runtime.log {
roll_size 500mb
roll_keep 3
roll_keep_for 720h
format json
level INFO
exclude http.log.access
log access {
roll_size 1gb
roll_keep 5
roll_keep_for 2160h
format json
level DEBUG
include http.log.access http.handlers.reverse_proxy
:2019 {
metrics
net.tld.org {
reverse_proxy localhost:8000
port.marinero.hu {
reverse_proxy localhost:9000 {
dial_timeout 60s
read_timeout 60m
write_timeout 120s
keepalive 10m
mail.tld.org {
redir https://webmail.tld.org:2096
d.e.tld.org {
reverse_proxy localhost:8885
my.tld.org {
reverse_proxy localhost:8085
a.b.c.tld.org {
reverse_proxy localhost:7777
*.sss.tld.org, sso.tld.org {
dns cloudflare {env.CF_TOKEN}
@users host users.tld.org
handle @users {
reverse_proxy localhost:5000
reverse_proxy localhost:8998
