2.4.5
Docker for macOS v20.10.8
macOS 11.3.1
In folder containing Dockerfile and Caddyfile:
docker build -t caddy-test .
docker run -e "DYNAMODB_TABLE=caddy-storage" -e "DYNAMODB_REGION=us-east-2" -p 80:80 -p 443:443 caddy-test
Dockerfile
FROM caddy:2.4.5-builder-alpine AS builder
RUN xcaddy build --with github.com/silinternational/certmagic-storage-dynamodb@2.0.1
FROM caddy
on_demand_tls {
ask https://www.oursite.com/api/domain/verification
storage dynamodb {$DYNAMODB_TABLE} {
aws_region {$DYNAMODB_REGION}
lock_polling_interval 5s
lock_timeout 5m
https:// {
on_demand
rewrite * /web?uri={path}&host={host}
reverse_proxy https://www.oursite.com {
Neither the lock_polling_interval
nor the lock_timeout
from the storage config seem to be accepted by Caddy. It works if I omit those two options, but I prefer declarative, explicit configuration values as opposed to relying on implicit defaults.
Does the Caddyfile support the lock options for the dynamodb storage plugin?
{"level":"info","ts":1636041834.6633754,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: parsing caddyfile tokens for 'storage': /etc/caddy/Caddyfile:8 - Error during parsing: unrecognized parameter 'lock_timeout'
and (depending on which of the lock
options is first in the config)
run: adapting config using caddyfile: parsing caddyfile tokens for 'storage': /etc/caddy/Caddyfile:8 - Error during parsing: unrecognized parameter 'lock_polling_interval'
It works if I omit the values. I also tried removing the underscores, e.g. lockpollinginterval
but to no avail.
The documentation for the JSON config has underscores: Modules - Caddy Documentation
And this github issue for the dynamodb storage plugin mentions the lock options:
N/A
