Hello,
I’m trying to create a CaddyFile which allows me to authorize any domain, as long as I have a directory with its name in my folder, and to use this directory as root
For example: if the domain example.com has its DNS A pointing to my server, and someone visits example.com, I want to
- Check if I have a directory /home/codi/clients/example.com/
- If yes, issue the SSL certificate and launch the index.html inside
It’s my first time with Caddy and I start with a complex scenario … my Caddyfile could be really bad, I’m sorry if my question it not good
When I try with a test domain, nothing happens and I don’t see any log in my “caddy run”
Following the documentation, as a debian package
Debian
I tried caddy start first but to see what’s happening I’m using caddy run now
on_demand_tls {
ask https://check.codicommerce.fr
https://check.codicommerce.fr {
root * /home/codi/clients/
@deny not file /{host}/
respond @deny 404
on_demand
root /var/www/clients/{host}
I took inspiration for my CaddyFile on these links:
Thx!
