1. Caddy version:
2.6.2-alpine
Running on docker host
Ubuntu server 22.04
Docker version 20.10.22, build 3a2c30b
docker run
Caddy main config
import /etc/caddy/Sites/*.caddy
root * /usr/share/caddy
Caddy config to import
project.namespace.hostname:80 {
reverse_proxy container:80
Hello, i have a simple caddy setup. Caddy is running in a container and exposes various apache containers. With that it’s possible to access each apache instance though port 80 on http://project.namespace.hostname/ . The setup should be portable, but in the caddy files that are being imported the hostname is constant. So my question is, how it could be accomplished to have the hostname not in the config.
