1117
(小兵 刘)
1
Caddyfile configuration file:
Mywww.com
Tls /etc/ssl/caddy/mywww.com.crt /etc/ssl/caddy/mywww.com.key
Gzip
Timeouts none
Proxy /ray 127.0.0.1:12015 {
Websocket
Header_upstream -Origin
Root /var/www
V2ray config.json file:
“inbounds”: [
“port”: 12015,
“listen”: “127.0.0.1”,
“protocol”: “vmess”,
“settings”: {
“clients”: [
“id”: “d230b52a-1a37-40c0-a199-70f63c34ca1b”,
“alterId”: 233
“streamSettings”: {
“network”: “ws”,
“wsSettings”: {
“path”: “/ray”
“outbounds”: [
“protocol”: “freedom”,
“settings”: {}
Problem: caddy display is working properly and can’t connect to the internet
matt
(Matt Holt)
2
Hi there,
We’re aware of issues with V2Ray. Can you please post the following information:
- Your full Caddyfile (without changes)
- Your full logs (from your Caddy process log and/or systemd/journalctl)
- Full and complete error messages
Please use code blocks (3 backticks on their own line: ```) for code/config/logs.
Thank you!
yzongyue
(Yzongyue)
3
matt
(Matt Holt)
4
Yep, it’s most definitely a V2Ray problem. We’re debugging it here as well:
system
(system)
Closed
5
