Caddyfile configuration for reverse proxies - different behaviours
Attempting to set up a caddyfile to reverse proxy a series of different ports on a local machine to a subdirectory of a domain name. One of these (ombi) is working as intended, and reverse proxies perfectly. The remainder don’t work - either they result in a black screen (in the case of plex, dynmap) or a 200 error.
*   Trying 193.237.139.13:80...
* Connected to www.olliemon.co.uk (193.237.139.13) port 80 (#0)
> GET /plex HTTP/1.1
> Host: www.olliemon.co.uk
> User-Agent: curl/7.81.0
< Connection: close
< Location: https://www.olliemon.co.uk/plex
< Server: Caddy
< Date: Tue, 05 Mar 2024 12:22:32 GMT
< Content-Length: 0
* Closing connection 0
* Issue another request to this URL: 'https://www.olliemon.co.uk/plex'
*   Trying 193.237.139.13:443...
* Connected to www.olliemon.co.uk (193.237.139.13) port 443 (#1)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
*  subject: CN=www.olliemon.co.uk
*  start date: Mar  2 07:25:52 2024 GMT
*  expire date: May 31 07:25:51 2024 GMT
*  subjectAltName: host "www.olliemon.co.uk" matched cert's "www.olliemon.co.uk"
* Using Stream ID: 1 (easy handle 0x55b9f25c9eb0)
> GET /plex HTTP/2
> user-agent: curl/7.81.0
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Tue, 05 Mar 2024 12:22:32 GMT
* Connection #1 to host www.olliemon.co.uk left intact
linux package - apt get
Ubuntu 22.04.4 LTS - x86-64
Editing caddyfile via nano and reloading with caddy reload --config /etc/caddy/Caddyfile
# domain name.
https://www.olliemon.co.uk {
	root * /usr/share/caddy
	# php_fastcgi localhost:9000#
	route /ombi* {
		reverse_proxy 127.0.0.1:5000
	route /map/* {
		reverse_proxy 127.0.0.1:8123
	route /plex* {
		reverse_proxy 127.0.0.1:32400/web
	route /webmin* {
		reverse_proxy 127.0.0.1:10000
	route /amp* {
		reverse_proxy 127.0.0.1:8080
See this article:
You’d be much better off using a subdomain for each service.
You can’t pass a path as part of the upstream address. If you need to rewrite the path, you need to use the rewrite directive to do that. (But again – just use subdomains)
What would the caddyfile look like to reverse proxy to a subdomain? I’ve tried a few configurations and they all fail to validate, I am assuming it’s a syntax error
Just like this (and add the rest as needed):
ombi.example.com {
map.example.com {
