Hello all, I have setup caddy with cloudflare tls in order to run my internal domains, and I’m having trouble getting caddy to work with kasm workspaces.
I have defined the GUI on port 4443 in the docker compose file, and am able to access the workspaces via my fqdn (https://monolith.lan:4443).
But, when I try to use my domain, I’m having what I think is websocket issues where the Host is https://kasm.lan.downlens.com:4443 and the origin is https://kasm.lan.downlens.com. Considering the domain with the port on the end is invalid, the workspace won’t load. I’ve included my Caddyfile with my attempted websocket matchers, but I’m not able to get the site to load with them.
Other than checking on the web browser, I’m not sure how to diagnose this issue.
Here is the docker compose logs output
caddy | {"level":"info","ts":1689631840.8412552,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | {"level":"info","ts":1689631840.8455288,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy | {"level":"info","ts":1689631840.8462577,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002a1dc0"}
caddy | {"level":"info","ts":1689631840.8464887,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy | {"level":"info","ts":1689631840.8465333,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy | {"level":"info","ts":1689631840.8478963,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"info","ts":1689631840.8478951,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy | {"level":"info","ts":1689631840.8479931,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
caddy | {"level":"info","ts":1689631840.8480375,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1689631840.8480716,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1689631840.8480766,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["gitea.lan.downlens.com","omada.lan.downlens.com","food.lan.downlens.com","switch.lan.downlens.com","fb.lan.downlens.com","home.lan.downlens.com","plex.lan.downlens.com","opnsense.lan.downlens.com","docs.lan.downlens.com","kasm.lan.downlens.com","pics.lan.downlens.com","cmk.lan.downlens.com","esxi.lan.downlens.com","ysep.lan.downlens.com","code.lan.downlens.com","pando.lan.downlens.com","ys.lan.downlens.com","sd.lan.downlens.com","backup.lan.downlens.com"]}
caddy | {"level":"info","ts":1689631840.8519728,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"info","ts":1689631840.8553364,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1689631840.8553464,"msg":"serving initial configuration"}
OS: Pop!_OS 22.04
Arch: amd64
local DNS: Unbound
Built using xcaddy via this dockerfile:
ARG VERSION=2
FROM caddy:${VERSION}-builder AS builder
RUN xcaddy build \
To start caddy:
docker compose up -d
version: "3.9"
build: ./dockerfile-dns
hostname: caddy
env_file:
- caddy.env
- "443:443/udp"
- ./data:/data
- ./config:/config
$ cat caddy.env
MY_DOMAIN=lan.downlens.com # replace with your domain
MY_HOST_IP=redwood.lan # replace with your Docker host's IP address
CLOUDFLARE_API_TOKEN=<api-token> # add your token
kasm.{$MY_DOMAIN} {
@websockets {
header Connection *Upgrade*
header Upgrade websocket
reverse_proxy @websockets monolith.lan:4443 {
tls_insecure_skip_verify
resolvers 1.1.1.1
