Caddy2 w/WordPress behind Caddy2 reverse proxy
caddy version   # file server
caddy version   # reverse proxy
v2.2.2-0.20201022184206-b6e96d6f4a55h1:P1bdaliL0KA5wk2Kq6ZzvgWmcTpBGH4Jus+laXHEN0Y=
freebsd-version
11.3-RELEASE-p14
service caddy start
n/a
Caddyfile for the WordPress file server
  root * /usr/local/www/wordpress
  php_fastcgi 127.0.0.1:9000 {
    env SERVER_PORT 80
    format json
    output file /var/log/access.log {
      roll_keep 7
  # External access denied to these files.
  @forbidden {
    path /wp-content/uploads/*.php
    path /.user.ini
    path /wp-content/debug.log
  respond @forbidden 404
Caddyfile for the Caddy reverse proxy
(tlsdns) {
    dns cloudflare <api_token>
(authproxy) {
  basicauth {args.0} {
    admin <hashed-password>
(logging) {
    format json
    output file /var/log/caddy/{args.0}.log {
      roll_keep 7
blog.udance.com.au {
  import tlsdns
  import authproxy /phpmyadmin*
  import logging blog
  reverse_proxy http://10.1.1.4
n/a
n/a
More a point of clarification. I did review the thread Caddy2 w/Wordpress behind nginx reverse proxy, which is very similar to this thread, the difference being an nginx reverse proxy being used there. I must admit to not fully understanding everything that was said.
My question relates to this WordPress extract about placing WordPress behind a reverse proxy.
If WordPress is hosted behind a reverse proxy that provides SSL, but is hosted itself without SSL, these options will initially send any requests into an infinite redirect loop. To avoid this, you may configure WordPress to recognize the HTTP_X_FORWARDED_PROTO header (assuming you have properly configured the reverse proxy to set that header).
# Code to add to wp-config.php when WordPress is behind a reverse proxy
define('FORCE_SSL_ADMIN', true);
// in some setups HTTP_X_FORWARDED_PROTO might contain
// a comma-separated list e.g. http,https
// so check for https existence
if (strpos($_SERVER['HTTP_X_FORWARDED_PROTO'], 'https') !== false)
$_SERVER['HTTPS']='on';
My question is about the bit of the quoted text ‘assuming you have properly configured the reverse proxy to set that header’. Do I need to explicitly set anything in the Caddyfile for the reverse proxy?
  1. Caddy2 w/Wordpress behind nginx reverse proxy
  2. HTTPS – Advanced Administration Handbook | Developer.WordPress.org
per the documentation:
By default, Caddy passes thru incoming headers to the backend—including the Host header—without modifications, with two exceptions:
It adds or augments the X-Forwarded-For header field.
It sets the X-Forwarded-Proto header field.
Yes, thanks for the reference. I did read that, but clearly, it didn’t register with me at the time. I see now that Caddy implicitly sets the X-Forwarded-Proto header field that is referenced in the snippet of WP code.
