giopas
(giopas)
May 22, 2022, 1:36pm
#1
2.5.0
caddy run --config /share/home/test.conf -agree -email test@gmail.com -root /home/Qhttpd -log /share/home/caddy2.log -pidfile /var/run/caddy.pid &
QNAP
b. config file
xx.iiiiii.xyz {
log / /share/home/xx.log
reverse_proxy http://192.168.10.7:4040
What Caddy v.1 I was using the command line mentioned under [2] above (except config, of course). But now I receive the error:
flag provided but not defined: -agree.
Usage of run: (…)
What I am missing, how should I pass the -agree, -email, -log and other settings in the string?
Thanks!
Caddy v2 is a complete rewrite from Caddy v1. The CLI has significantly changed. See the docs, all those options other than --config
do not exist anymore.
Make sure to name your config file Caddyfile
, not test.conf
See the upgrade guide:
giopas
(giopas)
May 22, 2022, 10:17pm
#3
Thank you. I am trying to learn more and I have modified the lunch script as follows:
./caddy run --config /share/home/caddy/caddy2-conf -->watch --pidfile /var/run/caddy.pid &
The config file is the following:
output file /share/home/caddy/caddy2.log
eg.example.xyz {
log / /share/home/caddy/example.log
However if I run a test, I get:
./caddy validate --config >/share/home/caddy/caddy2-conf
2022/05/22 22:13:05.018 INFO using provided >configuration {“config_file”: >"/share/home/admin/caddy/caddy2-conf", >“config_adapter”: “”}
validate: decoding config: invalid character ‘l’ looking >for beginning of object key string
What am I missing?
Like I said, name your config Caddyfile
Caddy’s underlying config is JSON. The caddyfile is an adapter that transforms a Caddyfile config into JSON.
Also, your log
directive inside your site block is not correct. Review the docs for the log
directive.
Also, don’t use &
when running Caddy to put it in the background. Instead, you should run Caddy as a systemd service.
If you install Caddy with one of the methods on the Install — Caddy Documentation page, it should already be set up for you to run as a systemd service.
But it seems like QNAP does their own weird stuff so you don’t have systemd: Running Your Own Application at Startup - QNAPedia
giopas
(giopas)
May 23, 2022, 5:49am
#5
Ok, thanks.
Now in my sh lunch script, I have:
./caddy run --config /share/home/caddy/Caddyfile -->watch --pidfile /var/run/caddy.pid &
The config file has been renamed as Caddyfile and it is like the following:
email example@gmail.com
eg.example.com {
http://xyz.example.com {
reverse_proxy http://192.168.10.7:8000
Now it seems working!
I just need to learn:
how to put logs back (they are used for goaccess),
how to use the following reverse proxy argument (as it was under v.1): http://192.168.10.7:5678/directory
how to use authentication for a single site (that should be easy)
how to use gzip. Under version 1, I had the following part in the general section. Can I use the below?
gzip {
ext *
level 7
min_length 1
Thanks again for guiding me through it!
giopas:
Just use the log
directive.
Make sure to update your goaccess config to use Caddy’s JSON format.
giopas:
Do the rewrite beforehand, with the rewrite
directive.
giopas:
Depends on the kind of auth you need. Did you read the docs?
You’re looking for the encode
directive. No need to configure gzip level/length, just use encode gzip
giopas
(giopas)
May 23, 2022, 2:02pm
#7
Thank you!
I did some more digging, and - beside the fact that I still need to look into goaccess config to be sure I can use Caddy’s JSON format - this is new configfile I am building (which I cannot test now as I am outside the LAN):
header Strict-Transport-Security max-age=31536000;
eg.example.com {
outputfile /share/home/caddy/example.log
rewrite http://192.168.10.7:8000 http://192.168.10.7:8000/directory
http://abc.example.com {
basicauth {
Bob JDJhJDEwJEVCNmdaNEg2Ti5iejRMYkF3MFZhZ3VtV3E1SzBWZEZ5Q3VWc0tzOEJwZE9TaFlZdEVkZDhX
Is the gzip, log, rewrite, header and basicauth syntax correct?
Of course for the latter, I understand that I need to use caddy hash-password
Thanks!
Rewrites only work on the request path and query, not the whole URL. This is incorrect.
These are site directives, not global options. They aren’t valid here. You need to put them in each site.
You missed a space between output
and file
here.
Also, please run caddy fmt --overwrite Caddyfile
to clean up your config’s syntax.
giopas
(giopas)
May 23, 2022, 4:09pm
#9
Thanks!
Does it mean that I have to use something like the following?
rewrite * /directory
To preserve the original URL, you’d need to do this:
rewrite * /directory{uri}
giopas
(giopas)
May 23, 2022, 7:31pm
#11
thank you, all done! After a couple of years (or more) I finally moved to Caddy2
system
(system)
closed
June 21, 2022, 1:37pm
#12
