1. My Caddy version (caddy -version
v2.0.0-beta6 h1:tGZaM3NfxlBZhllJYKEehYYY9SMOyz8UNjMBoYALaT4=
caddy is installed in /usr/local/bin/caddy
centos-release-7-7.1908.0.el7.centos.x86_64
systemd 219
caddy start -adapter caddyfile -config /caddy/caddy.conf
> no compose file
d. My complete Caddyfile:
www.domain2.com:443, domain2.com:443 {
reverse_proxy / ip-address:port
I have installed caddy version 2 yesterday. Experimented with domain1.com
as a load balancer / reverse proxy and it was working great. Happy with it.
Today I tried to use with domain2.com
and noticed the error rate limit applied by letsencrypt . One thing I forgot was pointing the domain to the IP address when I tried to start caddy.
2019/10/22 05:21:19 Caddy 2 admin endpoint listening on localhost:2019
2019/10/22 05:21:19 [INFO] Enabling automatic TLS certificate management for [www.domain2.com domain2.com]
2019/10/22 05:21:19 [INFO][cache:0xc000099a40] Started certificate maintenance routine
2019/10/22 05:21:19 [INFO][www.domain2.com] Obtain certificate
2019/10/22 05:21:19 [INFO] [www.domain2.com] acme: Obtaining bundled SAN certificate
2019/10/22 05:21:19 [ERROR][www.domain2.com] failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt, url: (attempt 1/3; challenge=http-01)
2019/10/22 05:21:20 [INFO] [www.domain2.com] acme: Obtaining bundled SAN certificate
2019/10/22 05:21:20 [ERROR][www.domain2.com] failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt, url: (attempt 2/3; challenge=http-01)
2019/10/22 05:21:21 [INFO] [www.domain2.com] acme: Obtaining bundled SAN certificate
2019/10/22 05:21:21 [ERROR][www.domain2.com] failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt, url: (attempt 3/3; challenge=http-01)
2019/10/22 05:21:22 [INFO] [www.domain2.com] acme: Obtaining bundled SAN certificate
2019/10/22 05:21:23 [ERROR][www.domain2.com] failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt, url: (attempt 1/3; challenge=tls-alpn-01)
2019/10/22 05:21:24 [INFO] [www.domain2.com] acme: Obtaining bundled SAN certificate
2019/10/22 05:21:24 [ERROR][www.domain2.com] failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt, url: (attempt 2/3; challenge=tls-alpn-01)
2019/10/22 05:21:25 [INFO] [www.domain2.com] acme: Obtaining bundled SAN certificate
2019/10/22 05:21:25 [ERROR][www.domain2.com] failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt, url: (attempt 3/3; challenge=tls-alpn-01)
I pointed the domain domain2.com to an entirely new ip address.
Tried starting domain2.com via caddy. But it still shows the letsencrypt rate limit has occurred. On further checks I noticed a message as
2019/10/22 05:45:53 http: TLS handshake error from ip-address:46502: tls: first record does not look like a TLS handshake
I have noticed this error message many times when I started caddy yesterday. I wonder whether this has something to do with rate limit or due to the domain was not pointed to the ip when I tried to start caddy caused the rate limit issue.
It would have been nice if caddy don’t exceed too many requests when we issue only a single command like caddy start if the domain ip is not pointed.
One last question is what will happen if we have multiple domains in single caddyfile and an ssl certificate renewal failed due to some reason, does all servers goes down / fail to reload ?
