Is it possible for caddy2 to listen on unix socket? ( not proxy-ing to unix socket )
I have haproxy in front of caddy2 and i want to use unix socket instead of tcp port, is that possible?
Hi @Dejan_Milosevic! Welcome around
Yes, Caddy 2 can listen on Unix sockets. The listen
key in the JSON config takes something known as network address
. The network address is of the form network/address
, where in your case the network is unix
. So your config value will be something like this:
unix//path/to/unix/socket
Oops! Be careful if you are using beta 15. beta 15 has a bug:
https://github.com/caddyserver/caddy/issues/3101
Only on the reverse proxy. Already fixed too.
