Caddy2 clustering
I did not see in the documentation a description on running multiple Caddy2 instances in a cluster that share ACME data and general configuration. Can we use Consul or Redis as a backend to share/distribute the configuration / ACME data?
Do I need to run an odd number of Caddy2 servers in a cluster? Is the structure primary => secondary or does every node in the cluster act as a primary?
Hey Justin,
Running Caddy in a cluster currently means that it will share certificates and other assets/data with the other instances in its cluster. A cluster is defined as Caddy instances which are configured to have the same storage as the other instances.
The website doesn’t yet have docs for third-party modules (I’ve been working on that the last two weeks… hopefully will have something to show later this week). For now, you can see what modules are available here: https://caddy.community/t/list-of-caddy-2-modules/7839?u=matt
One of the categories is storage modules. The default storage module (file_system) is included, so it is on our website: Modules - Caddy Documentation
Yes to both. As you can see from the wiki, third-party modules currently include Consul, Redis, and DynamoDB.
Caddy instances that are configured to have the same storage will share data assets, for example TLS certificates: Automatic HTTPS — Caddy Documentation (and they will even coordinate solving the ACME challenges together so you don’t have to take any pains of configuring a load balancer to handle those specially!) – Caddy does this automatically. For example, if you configure all to use the same redis DB or file system folder (maybe a network mount), Caddy will automatically share a single copy of every TLS certificate, and even coordinate its management so that if one initiates a renewal of it, another one can solve the ACME challenge and finish the renewal. They don’t need to talk to each other directly: it all happens through atomic operations in storage.
No.
Typically, every instance that uses a storage module to coordinate/share or in other words “join a cluster” is primary.
