deip
(deip)
1
Hi, I just upgraded from caddy 2.8.4 to 2.9.1 and after restarted my caddy container, I see new WARN messages in the logs:
WARN http HTTP/2 skipped because it requires TLS {"network": "tcp", "addr": ":12345"}
WARN http HTTP/3 skipped because it requires TLS {"network": "tcp", "addr": ":12345"}
WARN http HTTP/2 skipped because it requires TLS {"network": "tcp", "addr": ":80"}
WARN http HTTP/3 skipped because it requires TLS {"network": "tcp", "addr": ":80"}
Im exposing some services in raw HTTP, for example
:12345 {
log http-logger
@nope not remote_ip private_ranges
respond @nope "?" 404 {
close
crowdsec
root * /var/www/site
These services are still working as expected. But I’m not sure how to get rid of those warnings?
fds
(fds)
2
It’s really just an entirely harmless reminder that you’re missing out on all the goodies of both HTTP/2 and HTTP/3 by not using https!
If you must, you can silence the warning by spelling out that you’re only enabling HTTP/1.x.
Add this in the global section:
servers {
protocols h1
Note: this goes in the global section, ahead of the per-site configuration part you posted. See the documentation for details.
Crydsch
(Crydsch)
4
Hey, i have the same Warning, also after upgrading.
INF | ts=1737292853.4896452 logger=http.auto_https msg=server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS server_name=srv0 https_port=443
INF | ts=1737292853.489657 logger=http.auto_https msg=enabling automatic HTTP->HTTPS redirects server_name=srv0
INF | ts=1737292853.4896927 logger=tls.cache.maintenance msg=started background certificate maintenance cache=0xc000726280
INF | ts=1737292853.4921868 logger=http msg=enabling HTTP/3 listener addr=:443
INF | ts=1737292853.4922445 logger=http.log msg=server running name=srv0 protocols=["h1","h2","h3"]
WRN | ts=1737292853.4922554 logger=http msg=HTTP/2 skipped because it requires TLS network=tcp addr=:80
WRN | ts=1737292853.4922576 logger=http msg=HTTP/3 skipped because it requires TLS network=tcp addr=:80
INF | ts=1737292853.4922585 logger=http.log msg=server running name=remaining_auto_https_redirects protocols=["h1","h2","h3"]
I use caddy for https termination and as a reverse proxy.
However, all of my subdomains use the https schema.
https://sub.domain.com {
reverse_proxy 192.168.123.456:7890
Do you know why I get this warning?
system
(system)
Closed
5
