Caddy1 proxy errors page
v1.0.3
I just execute caddy with my CaddyFile on the same directory.
OS, relevant versions, systemd? docker? etc.
Ubuntu, 64bit
caddy -conf CaddyFile
d. My complete Caddyfile:
mydomain.com {
        tls myemail@gmail.com
        proxy / http://localhost:8080 http://localhost:8081 {
                fail_timeout 1m
                try_duration 2s
        errors {
                502 /home/website/maintenance/maintenance_502.html
I want to show that .html page when no proxies are online, currently when this happens I just get a page showing 502 error page, but not the .html page I made.
Error logging is enabled (I can see it on the terminal) but the page is not rendered.
Hi @Raggaer, welcome to the Caddy community.
As far as I know, this is dependent on who generates the 502 - Caddy, or the upstream.
Can you post the Caddy error logs you’re seeing?
The results from curl -IL http://localhost:8080 and curl -IL http://localhost:8081 might be useful as well.
True @Whitestrake , I guess was wrong then with my question.
I would like to show that .html page when both servers are offline (:8080 and :8081). Is that something I can achieve?
I wouldn’t say your question was wrong.
To clarify my post, whether the custom error page is displayed depends on whether Caddy generated the 502.
If the upstream server returned a 502 to Caddy, Caddy will faithfully pass that on to the client - it’s a valid response from upstream, so Caddy won’t “overwrite” that response with a custom error page.
@Whitestrake The server does not return 502 since the sever is offline. Trying to contact it with curl -IL http://localhost:8080 or curl -IL http://localhost:8081 gives me Failed to connect.
So the 502 comes directly from Caddy, I am guessing.
Hmm.
Juuuuust to double check before I send you over to the issues page to file a bug, can you just confirm for me the output of ls -a /home/website/maintenance/maintenance_502.html?
It does exist. I noticed this issue: Custom error pages for proxy backend errors not possible · Issue #1447 · caddyserver/caddy · GitHub might be related to my problem :frowning:
