You can use Caddy easily now!
The new target is Glitch ( https://glitch.com/ ):
- Caddy v2
- Code: Glitch :・゚✧
- Result: https://caddyv2.glitch.me/
- Caddy v1
- Code: Glitch :・゚✧
- Result: https://caddy-v1.glitch.me/
I use templates
to ensure that Caddy works. It certainly works!
Even better, Glitch is now available for free! Thanks Glitch!
(Limited storage space and requests: Glitch Support - The page you are looking for doesn't exist (404))
For simple usage, click the icon at the top left and select Remix Project.
Then replace index.html
. Of course you can add files. It can be edited and uploaded online!
Also export to Git repository. Of course you can also import.
Caddy
in Code is an executable file. Install from Console in Tools (lower left)
Please update this according to license selection and version update.
Caddy v2:(2.0.0-beta15)
rm caddy
curl -L https://github.com/caddyserver/caddy/releases/download/v2.0.0-beta.15/caddy2_beta15_linux_amd64 -o ~/caddy
chmod +x caddy
refresh
Caddy v1:
rm caddy
curl -L "https://caddyserver.com/download/linux/amd64?license=personal&telemetry=off" -o ~/caddy.tar.gz
tar zxvf caddy.tar.gz
chmod +x caddy
refresh
Use the refresh
command to restart the project server. Of course you can use kill
instead.
Enjoy!
I think I need to add README, license, etc., but I’ll do that with your comments.
